What do you think the topspeed of a banshee with the following mods is:
Cpi inframes
Drag porting
16/39 sprockets
vforce3 reeds
coolhead 18cc domes
timing plate
35mm carbs
All around pretty worn out stock tires
In the street
Hmmm, that's some pretty high gearing for the mods you listed. What size tires you running?
20x10x9
21x7x10
Its not mine some guy i went riding with today said he topped out at 103.Thats pretty damn fast for what he has. :confused:
Cpi inframes
Drag porting
16/39 sprockets
vforce3 reeds
coolhead 18cc domes
timing plate
35mm carbs
In the street
here's a link that will give you an idea. http://home.earthlink.net/~gellett/banshee.htm
just change the the sprocket sizes, and the RPM that you think that engine will pull with those mods.
my banshee does 155mph no problem no joke
I call BS. Show us VALID proof
I also recall you saying this too....
i can lauch at 14,000 rpms and it screams i never go out of 3 rd gear yet make offer ill let it go for way cheap.
In that same post you said something about it hitting 130 at the top of 3rd, so are you telling us you only gain 25mph with 4th and 5th gear? :shoothead:
Just because a 750 may do 150+ in a streetbike chassis, doesn't mean it will on dirt in a banshee chassis...
I call bull too.
You forgot Trav....it's on Razrs. I'm sure it's hooking up pretty good on NOS...
:down:
