7mm is pointless when you can build a 10mm for the same cost...
Unless you have 4mil castings that you'd like to turn into 7mil. Otherwise I'd prolly jump straight to 10.
anyone got one on here what are youre thoughts and setups
I bought a 7mm already built and it ran very well.......
if I had built it myself I would have deffinately buit a 10.........unless there was a class CC size cut off in the way.......
like 450cc and under......
7mm would be about the best combination for that class.......and a 10 wouldn't qualify.....
i know price is the same.. but a 10 mill cub i am finding out wont run any harder do too reed size
anything over a 7 go cheetah..
Just wondering if anyone has one i am getting one built a 7 mill cub by Jeff at fast..
just looking for others
its a dune bike not a drag bike hahah
Ive always been told anything over the 10 go with the big cheetah.
same here just trying to find anyone running a 7 cub i guess not to many i guess.. well i know one that will be?????
I believe Holeshot on here had one in a drag frame, it seemed to run hella good last time I saw it. Might try to get ahold of him, perhaps he can answer some of your questions.
a friend of mine is putting together a 7mm cub for the clash.. so it should be out there for its first time out..
ive got a seven and i have no problems keeping up or beating 10s.NOT SAYING ALL 10s!!!!.it all depends on how your bike is set up ,,,the rider, and weight!!
Edited by 2bzy2p
have you started to build it yet? The suoer cub is about the same money better get the extra cc's
yea i looked into a super but was turned away from it. I am buiding a dune bike not a drag bike.. and the 7 cub sould already be overkill if there is such a thing. the super cub requires a different head wider bolt pattern and such and they are a little hard to come by right now i here the head is not being massed produced like the standard head.
