hawk363 Posted September 22, 2006 Report Posted September 22, 2006 just wondering what you guys think would be some good inexpensive upgrades to run on my banshee, already have toomey t5's k&n and jetted. want to get some more out of it without spending loads of cash Quote
Bill Posted September 22, 2006 Report Posted September 22, 2006 Adjustable timing plate(35),lighten your flywheel(50),shave your head(40)those are less expensive than most. Quote
csrmel Posted September 22, 2006 Report Posted September 22, 2006 those are good suggestions. other ideas to consider are not so much upgrades but maintence that helps out alot. lube up all the cables, linkages, grease the suspension. you would be supprised at how often a cable needs to be oiled. when my banshee was 3 months old i lubed the clutch cable and what a difference. now i do it every 3 months. Quote
dajogejr Posted September 22, 2006 Report Posted September 22, 2006 Adjustable timing plate(35),lighten your flywheel(50),shave your head(40)those are less expensive than most. 100% exactly what I was thinking.... Timing plate at +4 and a shaved flywheel will really wake that bike up. it'll get on the pipe faster and start haulin the mail... Do you have stock or aftermarket tires? Suspension, gearing and tires are often overlooked....all the power in the world won't do any good without getting it to the ground... Quote
hawk363 Posted September 23, 2006 Author Report Posted September 23, 2006 thanks guys, any good bolt on mods i could do before i start rippin into the engine? Quote
Bill Posted September 23, 2006 Report Posted September 23, 2006 Well bolt ons are A little more exspensive,V-Force 3 reeds are good.Noss coolheads are nice too. Quote
Ron Burgandy Posted September 25, 2006 Report Posted September 25, 2006 How do you mean shave the flywheel? how do you do this? Adjustable timing plate, shave your head? what is this?how do you do this as well? Quote
Bill Posted September 25, 2006 Report Posted September 25, 2006 Well you want someone who knows what their doing when it comes to shaving the head and lightening the flywheel.Shaving the head will bump your compression up which will give you some more bottom end power.Lightening the flywheel will help your engine rev faster due to less restriction.Advancing your timing will give you more bottom end power,you can install one yourself but you need the right flywheel puller. Quote
hawk363 Posted September 25, 2006 Author Report Posted September 25, 2006 is it tough to pull of the flywheel even with this tool, or could i do it myself with basic mechanical skills Quote
Bill Posted September 25, 2006 Report Posted September 25, 2006 You can get the puller off ebay for like $22 plus shipping,I wouldnt attempt it without one.And definetly dont use the finger type puller on it,all youll do is damage it. Quote
olmick Posted September 25, 2006 Report Posted September 25, 2006 i think i got my puller off of vitos for bout 10 bucks, i would recommend using an air gun to get the flywheel nut off and to screw in the flywheel puller bolt to get it off, a hell of alot easier than using a regular ratchet Quote
easyrider470 Posted September 27, 2006 Report Posted September 27, 2006 After you get the puller....pop off the flywheel....you might need a buddy to help by holding the flywheel with a strap wrench so you can loosen the nut on it.....you should do the 35 dollar timing advance while you do the flywheel.....you have access to all that stuffwhen the flywheel is off and it's very easy to do.....rickey stator.com i thin is the web site....you can get the timing plate from them....35 bucks..... Look up booneman on here he does the flywheels for around 60 bucks.....he did mine and you can really notice a difference in the revs... Quote
dajogejr Posted September 27, 2006 Report Posted September 27, 2006 I agree...timing is a cheap mod too. Put some grease on the threads of the flywheel puller before you screw it into the flywheel. Also...a 1/2 impact gun works much easier and nicer than a strap and breaker bar!!! Quote
Animalman294 Posted September 27, 2006 Report Posted September 27, 2006 How do you mean shave the flywheel? how do you do this? Adjustable timing plate, shave your head? what is this?how do you do this as well? Man, when I read that I started rollin'. the first thing that went through my brain was............ well first find a really good razor in one hand and a mirror with some Gillette foamy in the other hand................ I heard when you shave your head it helps with the aerodynamics, especially when you duck down when you are slamin' gears................ :yelrotflmao: Just kiddin' man, welcome to the HQ. We all started somewhere................... :beer: Quote
