Hey guys, I'm having a problem with my Banshee pushing gear oil up through the overflow when I'm running it hard. A couple weeks ago I noticed my oil turning milky so I did the obvious thing and put in a new waterpump seal and made sure everything was sealed up tight. Well last trip out with fresh oil to start it started pushing oil out the overflow, I checked the oil and its milky again, I'm thinking possibly the right side crank seal is leaking which is pressurizing the crankcase and the fuel/oil is turning the gear lube milky. What do you guys think?
Does it have any gear lube coming into the area where you crank is.
No, not the coolant over flow. The oil is actually pushing through the crankcase vent. There is the tube that is at the back/top of the cases and there is also the tube that hooks into the case behind the water pump cover, they "T" together above the carbs and then the line runs up over top of the steering hoop. Oil is pushing all the way through there and then dumping out on my pipe. I know absolutely that it is not the coolant over flow as I have that run underneath the quad and also I haven't been losing any coolant at all.
You didn't put too much tranny fluid in, by chance...did you?
It's about 1.7 quarts of fluid or so...
Since you're in mid-michigan, stop by and see Bob at R&B racing. He sells a leakdown tester.
All you gotta do is take your pipes and carbs off and test for a leak. If a crank seal is leaking, the tester will show a drop in pressure...
Bob's in the Saginaw area, helluva nice guy to boot. You can PM here, his name is machwon.
Good luck...
Good luck...
Sounds like the way to go.Every crank seal problem i've had has always put gear oil in the cylinder and smoked more.
I may be a lil rusty but don't recall anything down there that would milk the fluid or cause excessive pressure other than anything obvious.
hmmmmmmmmmm..i'll get back w/ya
Dune
i think i recall somewhere on this site someone saying, that if you oil is milky that means your clutch is going out. not sure it thats true or not but thats just what someone said.
If your oil is milky looking it's from coolant or water getting into your case. Check your head and base gaskets and re- torque to specs. Also possible warpage?
good luck
hhhhmmmm, I've smoked my share of clutches before and none of them have made the oil milky. Typically when you have a milky white oil its water but I just put a brand new waterpump seal in it, and I checked the o-ring where the side case seals and sealed it with silicone also. At the same time the thing seemed to be running great and no excessive smoking. I guess I will have to get a leakdown tester to find out for sure.
good luck
It has a new head gasket in it from about a month ago because it was pushing water out the overflow, however that was with a cheap aftermarket gasket, haven't had a problem since I put a good oem gasket back in it. I don't understand how water would get into the gearcase from a bad base gasket or head gasket though since the crankcase is seperate from the gearcase.
Metal shavings? Yes. Milky? no.
Yeah, I have a home made tester that doesn't work for crap, and pieced it together just as Bob was selling his kit. I think it would've cost me 10 bucks more than what I pieced together...but his will work.
I'm gonna pick one up from him one of these days...(I'm hoping from all the referrals, he'll just send me one...ha ha...J/K Bob)... I'll just wait by the mailbox for my Christmas card, though...:)
:beer:
Bob bought my OEM Cylinders (virgin, non-bored) and stock crank from me. Good guy to talk to, very quick to respond and professional.
i am also getting oil out of my overflow , just had bottom end rebuilt with new seals .
the best part is while i was doing my top end i sent out my bottom to a local shop and had it checked out and new seals put in ( nothing broke , just wanted to make sure ) and now it spills oil out , and shop says its nothing they did wrong. so now my bottom has to be rebuilt AGAIN !!!
where can i buy a leak down tester kit ???????
PM him on here, he'll set you up.
