In need of the rear brake setup. Need everything but the pedal. I desire one that already has the brake block off done to it. Also any brake line will work as it will probably get replaced with an extended one. Let me know what you have, price you want for it shipped , and the condition that it is in. I will send money through paypal as gift. Thanks
Need an axle. Has to be straight as an arrow not even a slight wobble. PM me what you have. stock, aftermarket, doesnt matter. I dont really have a lot of money to throw at this but PM me what you have. Thanks
I'm working on a winter custom project. The front sprocket and the chain are a 530 but my rear is the complete banshee back end. Are you positive that I can run the 520 banshee sprocket on the the 530 chain ? Is there any draw back to doing this? Does it wear the chain and sprocket out faster? Could the chain slip off the rear sprocket? I see these guys running sport bike engines in banshee frames. Do they just use the stock 520 sprocket or change to a 530? Thanks for the good info.
I know that the banshee runs a 520 chain and sprocket size, I was just wandering if anyone knows of a place to get 530 rear sprockets that bolt up to the Banshee sprocket hub. Or know of another bike or 4 wheeler that comes stock with a 530 that will bolt up to the shee. Thanks
So I have been working on a project that uses a banshee carrier and axle to turn a motorcycle into a trike. So far it is coming together perfect but I am concerned about the carrier bearings. I am using Bearings that feature low-drag double lip rubber seals on both sides and have seals that go on the outside of them to keep the dirt and dust out. I know that these are made for a banshee that isnt really driving a constant 70mph for hours on end. I was wondering if anyone knows anything about this? I would hate to put this all together then have it melt carrier bearings while driving it.
Thank you sir. Just also want to make sure im right that the blaster bolt pattern is a 4x100 and the shee is a 4x115. (when talking about the rear hubs)
Just wondering if hubs off a blaster will fit the spline pattern on my banshee axle. I need the 4x100 blot pattern from the blaster hubs. Anybody out there know if it bolts up?
Hey, I have a trinity 2 into 1 with a 38mm keihin flat slide carb, 6in k&n filter, two cables(one for stock thumb throttle and one for a twist throttle, you can have em both), and every thing to mount it. PM if you are interested.
-darin
Hey, I have a 2 into 1 carb setup with a 38mm keihin flat slide carb, 6in clamp on k&n, two cables(one for a stock thumb throttle and one for a twist throttle), and everthing needed to mount it. It is 100% complete. PM me if you are interested.
-darin
Hey I have a lonestar +2 chrome axle. the chrome is in ruff shape but the axle is straight as an arrow and with a little polishing it could look pretty good. send me a pm if you are interested
-darin
