I'm not sure if it's like looking at your own newborn versus someone elses baby, but my quad is beautiful! I just had it delivered this morning, ran it around the block and let it cool down several times and headed for the swamps. I rode in some of the nastiest "swamp mud" and got stuck five times. My brother-in-law winched me out on his Polaris 700 each time and we were off. The only problem is my low-speed jetting. From idle to 1/4 throttle position Sheera bogs or has very little throttle response. I've read in the jetting section about the pilot or air screw settings, but being that I have no experience working on her yet I'm going to take her to a dealership down the road for help and hopefully watch how they work on the carbs. The bike came from the dealership with a K&N (lid on), FMF Gnarly and 280 mains (300ft elevation and no engine mods), but I don't know any other jet settings. My mother-in-law took a picture of it after I sprayed her off today, so I'll scan it in when the film is developed. I feel like a proud pappa! :baseball_santa:
Edited by nomad
That "bog" your talking about isnt the jetting. Its simply what your going to see with any 2 stroke. They make GREAT power, but the power band is narrow, and HIGH in the RPM range.
Are you sure about that?
When I got my banshee bran spankin' new, it did that very same thing.
I had a pretty crappy off idle hesitation.
When I put my pipes on, I got rid of that "bog" off idle when I re=jetted for the pipes.
COngrats on your new banshee. They are hella fun. :clap:
If you're going to have it re-jetted, it may be a good time to consider any minor mods (eg: removal of airbox lid, aftermarket reeds) since this all affects the fuel mixture and would require jetting changes for each.
Mud? what a shame.
Yeah...I think they delivered the wrong quad. You wouldn't take a vette or Mustang GT out in the mud would ya? (OK...OK...maybe if it was a friends, and you were drinking...and it was on a bet/dare...:) )
Same difference...
Hi all:
Some of you guys spend hours polishing your 'Shees because you've spent hours installing mods and tuning them for pure straight-light performance. That is understandable and they look awesome! However, I see no problem with getting dirty once in a while. The high power and low weight make it pretty good for moist trails. Sometimes opening her up across a muddy patch of trail is the only way to blow the smoke out.
I wouldn't "bog" with a Banshee though and definately not with a fresh engine. You need air moving across the radiator. While there are as many ways to break-in an engine as there are riders I don't think anyone seriously suggests running near wide open throttle with little to no air movement and cool water splashing all about.
The "bog" is so bad that when I'm in nuetral, it won't even rev up; it just putters. I raised the idle slightly and closed the air screws from 3 full turns to 1.5 turns. It runs a little better in gear, but still can't rev the engine at all in nuetral. I got stuck in the mud because i refused to rev the engine high enough to get outta of it. I only barely touched the "power band" 2 times in 1.5 hours in 2nd and 3rd gears. I only hit 4th gear once. As for the people talking about getting her dirty...IT's A QUAD....AN OHV! What the hell are you supposed to do with it (rhetorical)!?! It's gonna get dirty sooner or later. The water in NJ seems to take the dirt off: Maybe it's acid water
Edited by nomad
You've got a corvette and a Ford 4X4 truck in your garage.
Do you drive your truck in the summer and the vette in the winter, in the snow, in the rain...etc?
But why not, it's a car...it'd designed to be driven on roads....right?
A word comes to mind:
purposebuilt.
Not saying you can't take your shee through the mud...but, there's better alternatives....
You wouldn't buy a champion thouroughbred race horse in it's prime, bring him to your house and use it as a circus pony ride for kids, would ya?
Could it be done? Sure...
Fun? Maybe....
Better means available? Yep....
You're just taking a high reving, two stroke two wheel drive performance quad and taking it completely out of it's enviornment....
I have the same setup with the powerlid and gnarley pipes. I had a little bog til I changed the mix ratio to 32:1 and re-jetted. That factory 24:1 setup is just way too rich.
Thanks for the input. It's running very rich from the "factory" (smokey). I was told to mix it at approximately 32:1 by the dealership down the street.. I just mixed the gas up and I'm waiting to use the remainder off the original tank before putting in new fuel. I was shocked that the owners manual had it at (24:1). I have my fingers crossed.
purposebuilt.
Fun? Maybe....
Thanks for your $0.02! I'll put it toward a 4WD system for the banshee.
