00tbanshee Posted July 28, 2006 Report Posted July 28, 2006 who sells the best 4 mill crank, and would you go with a standard rod or 5+ Quote
BigRed350x Posted July 28, 2006 Report Posted July 28, 2006 who sells the best 4 mill crank, and would you go with a standard rod or 5+ Hotrods makes a good crank. Twister also makes a really really nice/expensive one. Definitely go with the 5mm longrod. Reduces stress on lots of parts and helps prolong engine life. - Jared Quote
dajogejr Posted July 28, 2006 Report Posted July 28, 2006 I second that. Also....make sure to have a reputable builder reweld that crank. Factory "welded" cranks from wiseco have been known to still have problems. Jeff @ FAST racing, Jim @ Passion, Redline, A&S, K&T...there are a ton that do it. Quote
jankab Posted July 28, 2006 Report Posted July 28, 2006 I second that. Also....make sure to have a reputable builder reweld that crank. Factory "welded" cranks from wiseco have been known to still have problems. Jeff @ FAST racing, Jim @ Passion, Redline, A&S, K&T...there are a ton that do it. I agree Quote
RATBIKE0130 Posted July 28, 2006 Report Posted July 28, 2006 Crankworks... www.crankworks.com No need to have the thing rewelded. You can have max load or tz bearings installed as well. Quote
dajogejr Posted July 28, 2006 Report Posted July 28, 2006 I don't see any prices on their site...do you happen to know how much their 4 mil cranks are? I know with maxload PTO bearing and a good reweld, a hot rod will cost about 600 bucks total. Is Crankworks comparable in price? Quote
00tbanshee Posted July 28, 2006 Author Report Posted July 28, 2006 thanx everyone :beer: check out wwwmotosport.com looks like they have great prices on 4mill kits Quote
Animalman294 Posted July 28, 2006 Report Posted July 28, 2006 Motosport has good deals, but are the cranks re-welded? You don't want to take the chance and have it break, then its really going to get expensive. So the money you save now will just be spent later............... :beer: Quote
00tbanshee Posted July 29, 2006 Author Report Posted July 29, 2006 Motosport has good deals, but are the cranks re-welded? You don't want to take the chance and have it break, then its really going to get expensive. So the money you save now will just be spent later............... :beer: if not i would have it trued and welded Quote
FASTOYS Posted July 30, 2006 Report Posted July 30, 2006 if not i would have it trued and welded They do come welded BUT are not holding up on high Hp motors and need to be rewelded before install! Quote
