I think a 120 pin(longest most shops carry) would get you close but maybe a couple links shy... I would recomend getting a mesurment (run the chain route with string) and get ahold of Jeff at FAST Racing. He sells it by the foot and that way you can worrie about CUTTING a bit of chain off rather than having to add.. He can be reache don here by pm his name is FASTOYS or phone # 785-364-5325
RIPPEN
I just looked on my bill...Jeff sent me one for my 6inch over...but it doesn't tell how many links.
Gold X Ring chain for 81 bucks... And I had to cut off about 8 or 9 links. Like he said, easier and stronger to take 'em off than add 'em back on.
And that chain is a GOOD chain... I was just think and I remembered buying a 120 pin when I was geard 13/42 or 43 and thats when I was a couple links shy. You may skate by with a 120 but as I said before its much more simple to measure and order..
RIPPEN
i got a 120 had to add 2 master links with 13 41
I had a gold DID X Ring last year...before my cub motor. Only one day trip to Silver Lake...had no problems.
My RK on my cub never got to run the sand...build problems... :wink:
Non-Oring or X Ring chains are better for drag racing...and that's pretty much due to less weight.
Although i haven't put much time on my new one...my old one got the piss beat out of it last year, and I gave it to my buddy that bought a bone stock 98...and the stocker was kinked as hell.
His 280 lb ass on it...a couple of trips...and it still has barely stretched at all, not even to the point of where I'd adjust it.
If you want the best, period...look at Sidewinder. The tensile strength of their chain is almost double the next best. However...you sure as shit pay for it...
If I had a ton of loot, that's what I'd have no questions asked!
