'shee Posted June 13, 2006 Report Posted June 13, 2006 I dont know how to get it out... It feels like i got the metal sleeve just spinning on the inside, any ideas how to get it out?? :baseball_bat: Quote
[email protected] Posted June 13, 2006 Report Posted June 13, 2006 (edited) PRY ? or just yank it until ure plastics make a huge hole and comeoff ? lol that sounds like ure in one of those situations where something is gunna get " customized " ....... good luck Edited June 13, 2006 by [email protected] Quote
FasterThanU90 Posted June 13, 2006 Report Posted June 13, 2006 i have the same prob with my tank both the bolts are stripped i cut the fender plastic like the gas tank shroud is notched and pulled like a muther.. :thumb: im eventually gonna buy a new tank Quote
91-421 Posted June 13, 2006 Report Posted June 13, 2006 i have the same prob with my tank both the bolts are stripped i cut the fender plastic like the gas tank shroud is notched and pulled like a muther.. :thumb: im eventually gonna buy a new tank Same thing, I ended up buying a new tank aswell. Quote
'shee Posted June 13, 2006 Author Report Posted June 13, 2006 i have the same prob with my tank both the bolts are stripped i cut the fender plastic like the gas tank shroud is notched and pulled like a muther.. :thumb: im eventually gonna buy a new tank Does it still stay in ok when the fender is notched? Quote
jankab Posted June 13, 2006 Report Posted June 13, 2006 I dont know how to get it out... It feels like i got the metal sleeve just spinning on the inside, any ideas how to get it out?? :baseball_bat: I have the same problem, just notch the plastic to get it off then take a cut off wheel and and cut around the plastic to get the bolt out, Then jb weld a new nut in Quote
Animalman294 Posted June 13, 2006 Report Posted June 13, 2006 I was going to suggest JB Weld or a high tensile plastic resin to glue it back into place. Hell you may even try super glue to hold it in place. Good luck............ :beer: Quote
87sheerips Posted June 13, 2006 Report Posted June 13, 2006 Heres what I did with mine that is in the same situation. I drilled a hole in each of those little tabs, and a corresponding hole in the middle flanges. One on each side. Then used a zip tie on each side to pull in the plastic with no bolt. It works great as a temp fix. Hope this helps. Quote
[email protected] Posted June 13, 2006 Report Posted June 13, 2006 theres always someone who figures out how to make a tie rap work in all situations Quote
350TwinDeathBed Posted June 13, 2006 Report Posted June 13, 2006 God dammit, I wish I had seen this thread about two weeks ago. I had the exact same problem, the bolt was just spinning and wouldn't come out. I ended up ripping the fucking thing out, along with the plastic that the nut sits in. In the process of ripping it out, I cracked the fender a bit where it mounts on and now there is also a hole that goes directly into the tank. So angry... I ended up buying a used tank on eBay, BansheeCJ3 happened to be the seller. If anyone can give me some pointers as to what I should do with the broken tank, that'd be great. Otherwise it is headed for the dumpster... :: Quote
jankab Posted June 13, 2006 Report Posted June 13, 2006 God dammit, I wish I had seen this thread about two weeks ago. I had the exact same problem, the bolt was just spinning and wouldn't come out. I ended up ripping the fucking thing out, along with the plastic that the nut sits in. In the process of ripping it out, I cracked the fender a bit where it mounts on and now there is also a hole that goes directly into the tank. So angry... I ended up buying a used tank on eBay, BansheeCJ3 happened to be the seller. If anyone can give me some pointers as to what I should do with the broken tank, that'd be great. Otherwise it is headed for the dumpster... :: You could JB weld the tank, it should hold up to the fuel. Just make sure you prep the area you're fixing. Quote
ellison445 Posted June 13, 2006 Report Posted June 13, 2006 Word :thumb: theres always someone who figures out how to make a tie rap work in all situations Quote
fastbanshee8 Posted June 14, 2006 Report Posted June 14, 2006 You could JB weld the tank, it should hold up to the fuel. Just make sure you prep the area you're fixing. Don't use JB Weld, because your 2 stroke oil will turn it to mush. You will have to find a 2 part epoxy, that's gas and oil resistant. I tried JB Weld on some carb caps once, and it lasted about 2 hours, then it turned soft, and peeled off like old used silicone. Quote
FasterThanU90 Posted June 14, 2006 Report Posted June 14, 2006 Does it still stay in ok when the fender is notched? yah just dont notch it too big just enough to slip the bolt through... i hat when pain in the ass stuff happens like this Quote
woodro77 Posted June 14, 2006 Report Posted June 14, 2006 get a torch , turn it up as high as it goes and heat it up till the plastic melts around the bolt , make sure the tank is full of fuel first, ( just kidding) Quote
