Hi everyone, went out today and noticed there is a quite bad viberation coming from the kickstart shaft and a slight viberation on the clutch and flywheel side so i dismanteled both sides and everything looked fine no play on flywheel or clutch basket the bike seems to run fine apart from this annoying vibe the bike is a totally stock 2003 model for now, any ideas what the problem could be thanx?
can you pinpoint where the noise is coming from? are you suer its the kickstarted. you listed a few different places of chatter. could be the bushing on the basket or an off balanced crank? do you have any specifics?
well when riding if i lean down and touch the kickstart shaft that's where most of the viberation is coming from like i say there is some vibes coming from the clutch and flywheel but the worst of it is defnitally coming from the kickstart shaft
