ive been running yamalube 32:1 since ive had my shee with no problems at all. i was at the parts store the other day and they sell ams oil i bought a bottle of the dominator racing oil on the back it says premix is 50:1 seems a little lean to me i relize that the ams oil is a full sythetic compared to the semi sythentic yamalube. does anybody else run this oil? what do you mix it at?
  • Replies 32
  • Created
  • Last Reply
Top Posters In This Topic
if that's what it recommends the mix to be, then that's what i'd mix it at. i would make sure to run the old gas (2r mix) completely out before adding the full synthetic so you don't have a mixture of the two. why do you want to switch anyway, cost??
i run the dominator at 32-1 even tho it says 50-1..
dominator oil dosent burn off as much so you can run it at 50-1. try 40-1 first if you find it smokes alot after wormed up.. then go to 50-1.. but i ran 32-1 but my engine was lean worked great..32-1 is always the safest way to mix your gas..
it all depends on your jetting really.. but ams oil is much better in my opinion..
its all i run..-dominator..
peace devin
I buy Yamalube 2-R in pints, makes it super easy to mix. 1 pint to 5 gallons of gas, 40:1. I have always have excellent luck with Yamalube so why change. My ported motor with wisecos has a very hard year and half on it and you can still see crosshatch in the cylinders. My buddies Banshee is on its 6th year I believe and still runs awesome with Yamalube at 40:1. I don't see any reason to switch.
520630[/snapback]
exactly the same here. I got the 5 gallon cans and just put a pint in each and fill it up and done :)
520665[/snapback]
That's why I'm curious about the pint price. My Amsoil is at max $2.70/ half pint. All I need to do is dump a bottle in a 5 gallon can and I've got 80:1. A box of 12 bottles mixes 60 gallons of gas for $32.40 shipped to your door. If you buy 4 quarts of 2R at $8.00/quart and mix 10 gallons/quart you've only made 40 gallons of premix for the same price. Something to think about.
Synthetic > Yamalube
Although I think the amsoil would mix fine with the yamalube, always safest to not mix, but don't worry too much. Just don't mix it with 927.
I got a few bottles of the 100 to 1 stuff and I plan to run it 40 to 1. it's very cheap cheaper than MC1 and cheaper than Yamalube.
The Interceptorr ran ok for me at 40 to 1 about the same as MC1, but it has alot different viscosity.
Edited by Justintoxicated
i seen some scary pictures of crank failures linked to amsoil 2 stroke oils on some snow mobile websites.. id be carefull running them. seems that amsoil doesnt protect so well and the cranks of a bunch of sleds rusted up and threw bearings.
What do those pints cost? When I used 2R it was about $9 for a quart.
520632[/snapback]
I buy it buy the case, I believe its $120-130 for a case of 24 pints. I get a 20% AMA discount so it runs me about $100 for 24 pints. Roughly $4 a pint, I know I can buy quarts cheaper but the pints are just really convienient especially when I have to fill up out on the trail they are easy to carry and use.
520821[/snapback]
From what I hear Synthetics are not ideal oils for Wet Environments.
I run interceptor in all my sleds and in the Shee' 40:1 it runs awesome for me, and I jetted it with the same ratio too, 40:1 interceptor. My older sled a 99 zl has 4500 miles on it same topend, always ams! I run it in the Firecat and ZR too! :cheers:
