Banshee_19 Posted May 14, 2006 Report Posted May 14, 2006 Has anybody had an experiences with the tether kill switches on the banshee? and would you recomend it? thanks http://www.hsdracing.com/Can/Scripts/prodV...sp?idproduct=93 Quote
kb7kuh Posted May 14, 2006 Report Posted May 14, 2006 I just installed one because I am going to run it at a dragstrip and it's required. They are easy to install, one wire to ground and one wire to orange wire on the coil. Quote
race-a-holic Posted May 14, 2006 Report Posted May 14, 2006 (edited) I was told that if you have a dyna ignition to not ground it to the frame.He told me to hook it up to the wires to the stock kill switch on the left side of the handlebars. That said.I've wired mine up but have yet to start it.Still waiting on my motor to get back. Edited May 14, 2006 by race-a-holic Quote
Banshee_19 Posted May 14, 2006 Author Report Posted May 14, 2006 so I went and picked up a kill switch this morning, installed it to the orage wire and it works great!! thanks for the help kb7kuh Quote
kb7kuh Posted May 14, 2006 Report Posted May 14, 2006 I have gotten so much help and advice here, I'm glad to give some back Quote
Banshee_19 Posted May 14, 2006 Author Report Posted May 14, 2006 its nice to see that people are willing to share their advice. I just got my banshee, first quad I have ever owned and all the help I can get is for the best. Thanks man Quote
FasterThanU90 Posted May 14, 2006 Report Posted May 14, 2006 can u guys post up a pic of how u installed it through the coil thanks Quote
bodge Posted May 14, 2006 Report Posted May 14, 2006 put one wire to ground and the other to the black/white wire from the cdi unit. Thats how mine is fitted. Quote
FasterThanU90 Posted May 14, 2006 Report Posted May 14, 2006 i wanted it mounted in the front not rear is this possible ? and mine says its a closed circiut switch and when pulled it connects the wires i was gonna do it through the key switch but they need to be looped to run im lost........ Quote
Banshee_19 Posted May 14, 2006 Author Report Posted May 14, 2006 I ran one wire to ground and the other to the orange wire going into my coil. The install at the coil was a little tricky due to the short wire and lack of space. Quote
DIRTMAN350 Posted May 15, 2006 Report Posted May 15, 2006 Same here just bolted on wire to ground on chassis and piggybacked the other wire to the orange wire at the coil. has worked good ever since. Quote
FasterThanU90 Posted May 15, 2006 Report Posted May 15, 2006 can sumbody just post a pic of where/ how they mounted it thanks Quote
DIRTMAN350 Posted May 15, 2006 Report Posted May 15, 2006 I'll take one monday and post it for ya. If ya need it earlier i'm sure someone can get one on here for ya. As far as mounting goes i used to have it mounnted to my bars but just recently i purchased a bar calmp from NOSS machine and it is custom made to mount on your bar clamp. Quote
blueshee03 Posted May 15, 2006 Report Posted May 15, 2006 Has anybody had an experiences with the tether kill switches on the banshee? and would you recomend it? thankshttp://www.hsdracing.com/Can/Scripts/prodV...sp?idproduct=93 515871[/snapback] they are required anywhere i've drag raced.in my oppinion the tether switch is a great idea on any atv or trail bike and should be mandatory .if they are in working order and the tether is attached to rider like its supposed to be and the rider is thrown off the motor will be shut down and prevent the machine from running off out of controll by its self and causing extra damage to its self or even worse an innocent bystander. Quote
