biggun6ss Posted May 10, 2006 Report Posted May 10, 2006 Got the nut off the bolt that goes through the swingarm but I cant get the bolt to come out. Is there a trick to getting it out? Quote
mnduner Posted May 10, 2006 Report Posted May 10, 2006 easyist way is if you have air to use an impact and keep spinning it while you use a 3/8 extension to push it out. try penatrating lube and a ratchet to turn it Quote
biggun6ss Posted May 10, 2006 Author Report Posted May 10, 2006 So it just comes out, ill give it a try. Quote
DIRTMAN350 Posted May 10, 2006 Report Posted May 10, 2006 I had to use a good swingpress and brass drift punch to get mine out along with an air hammer. Quote
BansheeBrian Posted May 10, 2006 Report Posted May 10, 2006 Yup, spin it with the impact and have a bud use a brass punch on the other end.4lb hammer shound convice it. Quote
Bansh88 Posted May 11, 2006 Report Posted May 11, 2006 You need a combination of spin and hammer. Wrench on it while giving it a tap from the other side Quote
