sschevy383 Posted March 11, 2006 Report Share Posted March 11, 2006 (edited) I'm gettin a weird backfire out the left side, on anything BUT full throttle. 03 Banshee...stock bore and port, T5's v force 3's, modified airbox with twin air filter. Stock carbs with 300mains. 4 degrees advanced thanks to ricky stator. TORS eliminator. Ever since i got the bike i had less exhaust out the one side, but when wide open, it would run great. The bike has little low end due to running on one cylinder, but when cranked open, she'll pull the wheels in 3rd gear I installed new reeds....no change took carbs completly appart and Swapped parts from left carb into right and right into left...no change removed TORS...no change I have no intake leak..ichecked with starting fluid The slides are in sync.... New exhaust did nothing either.... compression is 130 on both sides, i even switched the spark plugs and wires....still as a low end miss/pop out the left side. Low end is not 100%...more like 30% when i run anykid of part throttle...i can feel more exhaust on the right side...then when i open her full, she screams and the exhaust is the same! I'm confused, any idea's guys??? Thanks Ed Edited March 11, 2006 by sschevy383 Quote Link to comment Share on other sites More sharing options...
Hilarious Posted March 11, 2006 Report Share Posted March 11, 2006 Is the choke crossover tube, between the carbs, in place? Quote Link to comment Share on other sites More sharing options...
sschevy383 Posted March 11, 2006 Author Report Share Posted March 11, 2006 Is the choke crossover tube, between the carbs, in place? 485072[/snapback] Yes its is, this ones got me stumped. could a cracked piston give good compression, but have problems when running?? i'm going to pull the back carb boots off...and place my hand over the carb to see if its sucking...who knows.... Quote Link to comment Share on other sites More sharing options...
banshee tuner Posted March 11, 2006 Report Share Posted March 11, 2006 I'd say carbs or reeds has to be the problem. Quote Link to comment Share on other sites More sharing options...
holeshotkid Posted March 11, 2006 Report Share Posted March 11, 2006 Sounds kind of like a plugged pilot jet. That little orfice gets plugged real easy. Quote Link to comment Share on other sites More sharing options...
Turbobanshee_kid Posted March 11, 2006 Report Share Posted March 11, 2006 I'd say carbs or reeds has to be the problem. 485234[/snapback] That is what it sounds like to me or the needle jets are off sync. Quote Link to comment Share on other sites More sharing options...
sschevy383 Posted March 11, 2006 Author Report Share Posted March 11, 2006 Well its fixed, now idea what it was. Pulled eveyrthing appart again, cleaned with carb cleaner and compressed air. Now shes fine! Thanks guys Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted March 18, 2006 Report Share Posted March 18, 2006 Well its fixed, now idea what it was. Pulled eveyrthing appart again, cleaned with carb cleaner and compressed air. Now shes fine!Thanks guys 485362[/snapback] it was probably a plugged pilot jet, next time checkyour jettings when you clean the carbs, cause sometimes it will get lodged in there and you have to poke it out with something like a twisty tie. Quote Link to comment Share on other sites More sharing options...
