I'm gettin a weird backfire out the left side, on anything BUT full throttle.
03 Banshee...stock bore and port, T5's v force 3's, modified airbox with twin air filter. Stock carbs with 300mains. 4 degrees advanced thanks to ricky stator. TORS eliminator.
Ever since i got the bike i had less exhaust out the one side, but when wide open, it would run great. The bike has little low end due to running on one cylinder, but when cranked open, she'll pull the wheels in 3rd gear
I installed new reeds....no change
took carbs completly appart and Swapped parts from left carb into right and right into left...no change
removed TORS...no change
I have no intake leak..ichecked with starting fluid
The slides are in sync....
New exhaust did nothing either....
compression is 130 on both sides, i even switched the spark plugs and wires....still as a low end miss/pop out the left side.
Low end is not 100%...more like 30% when i run anykid of part throttle...i can feel more exhaust on the right side...then when i open her full, she screams and the exhaust is the same!
I'm confused, any idea's guys???
Thanks
Ed
