yamahakid1 Posted February 15, 2006 Report Posted February 15, 2006 where is the camber screw located/ what does it look like. If anyone has a picture that please post it. Quote
odaen Posted February 15, 2006 Report Posted February 15, 2006 Camber is set by the a-arms themselves. Most recreational a-arms aren't adjustable. When you get into the MX series arms, you get into camber/caster adjustable arms. You can see in the pic, where the upper arms connect to the frame, there's an adjustable heim. This is where you would set the camber. Quote
BigRed350x Posted February 16, 2006 Report Posted February 16, 2006 Mine adjust the camber down at the wheel end of the arms. Losen two nuts and put it where you want, then tighten them up. Quote
odaen Posted February 16, 2006 Report Posted February 16, 2006 argh, brainfart... yeah, my a-arms have a different type of ball joint that screws in vertically to the a-arm, so they can't be adjusted there. But, yeah, BigLobsterF'nRed is right. Quote
yamahakid1 Posted February 16, 2006 Author Report Posted February 16, 2006 wow sorry im talking about the screw in the shift shaft that centers itself so u can shift i thought it was called the camber screw Quote
Bansheeduner02 Posted February 16, 2006 Report Posted February 16, 2006 wow thats a big difference then Quote
banshee tuner Posted February 16, 2006 Report Posted February 16, 2006 That is a neat looking set of arms you have. Quote
