1995 Yamaha Banshee
$6,500.00
The motor was built by Rudy Kurtz in Hesperia, Ca.
Engine:
Type: 5 mil. 2 stroke, liquid cooled
Carburetion: 2 Keihin 35mm gas carbs w/pro-design intake
Ignition: PVL (cannot run lights)
Transmission: 6 speed (no reverse)
Chassis:
Frame: Stripped with all welds cleaned up with brackets not used removed.
Suspension/Front: Works tripple rate (chrome) shocks
Suspension/Rear: Stock Upgraded by Works
Brakes/Front: none (all mounts still in place)
Hubs/Front: Rpm
Brakes/Rear: Stock (polished brake cyl)
Hubs/Rear: Lonestar.
Tires/Front: Your choice of new
Tires/Rear: Your choice of new
Body:
Custom painted Silver with yellow tearing off.
The part list for this Banshee is as follows:
CPI Racing Exhaust-w/billet clamps
Machined Head
Aftermarket grill
Pro-Design bolt on billet aluminum parts
Lone star swingarm (+6)
Lonestar axle (2in. add from stock)
Adjustable timing plate
RTC clutch lever.
Banded clutch basket
This was a total strip down restoration. I have had this bike since new. Never has seen mud or field. I have no time to ride due to family. This bike has lots of chrome and polished work put into it, not only is it an eye catcher it is very dependable for a dune bike and racing it runs 105 -114 octane fuel.
The Banshee is located in Oak Grove outside of Kansas City, MO.
For Questions or to view the Banshee call Josh or Joe at H&H Extreme Atv.
Contact Joe @ 816-690-0007
  • 3 weeks later...
