ok, i have a 40 tooth in the back, 14 in the front, and im buying t5's off a buddy, right now i have pro circuits... i just also bought new rims off the same guy, but the rear ones were a different size, they were an 8 inch diameter, and my current tires are 10, so i bought new tires. the tires i bought were 20 inch tires, and i had 22 inch iRAZRs, so im just wondering if i should go up a tooth in the front, or drop a tooth in the back, for example go 15 in the front 40 in the back, or 38 in the back and 14 up front... or should i just keep it the way it is?
is the 15 in the front gonna hurt my low-end? i do mostly trail riding, with some wide open trails, and sometimes some street runs... the guy at work said i should either stay with the same gearing, or go to a 38 in the back...
466962[/snapback]
the 15 works fine in the trails,a little more cluth work if there real tight.
1 tooth in the front is worth 3 in the back.
I will run a 13 in the dunes. but run 14/15 in the trails.
and yes anything higher than a 15 will take from your low end a bunch.
I like the 15/41 setup too.
