JJBlink18206 Posted January 26, 2006 Report Posted January 26, 2006 whats size jets should i used with tommey t6 everthing else is stock Quote
banshee tuner Posted January 26, 2006 Report Posted January 26, 2006 It depends on your elevation. If your at sea level try 300 mains with 27.5 pilot and idle screws 1.5 turns out with the needle clip 4th from the top. That should be close. Quote
Turbobanshee_kid Posted January 26, 2006 Report Posted January 26, 2006 Get the toomey jet kit if you get the T-6's. I would get the T-5's myself but that is because i want porting. Quote
gatoman28 Posted January 27, 2006 Report Posted January 27, 2006 I also have a stock bike with toomey T6 pipes I was told to use 320 mains with 27.5 pilot jet, 4th clip on needle plus 1.75 turn on the screw. I dont know yet if it works I still have to try it myself, just thought I'd pass the info. Umberto Quote
2003LimitedBanshee Posted January 27, 2006 Report Posted January 27, 2006 I also have a stock bike with toomey T6 pipes I was told to use 320 mains with 27.5 pilot jet, 4th clip on needle plus 1.75 turn on the screw. I dont know yet if it works I still have to try it myself, just thought I'd pass the info. Umberto 464975[/snapback] The recommendations you have been given, and given again, are specific for your bike and riding location/conditions. He mentions that he is running everything else stock, whereas you have clamp-on K&Ns, and he presumably still has the stock airbox, possibly with the modded lid options that Toomey provides. Blink, you should probably be around 300-310 if you're running a slightly modded lid, at sea level, approx 60 degrees. You should be running a stock pilot, and needle around the 4th clip, either the stock or Dynojet needle that Toomey provides. Quote
FIRST BANSHEE Posted January 30, 2006 Report Posted January 30, 2006 whats size jets should i used with tommey t6 everthing else is stock 464734[/snapback] if your air box is untouched snorkle in place, stock air cleaner, the 280 will be close. any changes to the stock air intake system and you'll have to go bigger. Quote
