I also have a stock bike with toomey T6 pipes
I was told to use 320 mains with 27.5 pilot jet, 4th clip on needle plus 1.75 turn on the screw.
I dont know yet if it works I still have to try it myself, just thought I'd pass the info.
Umberto
Umberto
464975[/snapback]
The recommendations you have been given, and given again, are specific for your bike and riding location/conditions. He mentions that he is running everything else stock, whereas you have clamp-on K&Ns, and he presumably still has the stock airbox, possibly with the modded lid options that Toomey provides. Blink, you should probably be around 300-310 if you're running a slightly modded lid, at sea level, approx 60 degrees. You should be running a stock pilot, and needle around the 4th clip, either the stock or Dynojet needle that Toomey provides.
whats size jets should i used with tommey t6 everthing else is stock
464734[/snapback]
if your air box is untouched snorkle in place, stock air cleaner, the 280 will be close. any changes to the stock air intake system and you'll have to go bigger.
