how did you know the jetting was somewhat right with no sniffer???
thought wicked atv had a nice dyno facility???
451752[/snapback]
Is there a "sniffer" that can be used on a 2-stroke? I was always told the smoke from the burnt oil ruins the O2 sensor.
  • 8 months later...
  • Replies 61
  • Created
  • Last Reply
Top Posters In This Topic
Ok just for laughs and since the last guy that did this started a pretty interesting thread. Probably no prizes if you're right other than admiration and respect from other HQ members. Ask questions in case I left out any information...
Here's my engine mods:
+4 stroker/longrod crank w/ 65mm 795 series pistons (385 cc's)
mild dune port by Custom Creations
cut stock head running about 140psi
Timing plate at +4 degrees advance
1/2 112 octane running 32:1 on castor 927 (yeah I know I can switch back to 91 now, just using up what I have left).
V Force 2's with reeds in the LOW position
T5's
single 35mm pwk air stryker(dunno what jets yet, prolly 205+ mains, 70'ish pilot)
DIY Graydon style manifold
single clamp on K&N
Dirt Digger clutch w/ 3 HD springs
sea level, about 60-65 degrees
BansheeHQ go-fast sticker
ADDED BONUS: Guess my final jetting combo and win a free used plastic fork!
what size main jet do you use and what the bore?
