I just got my shee and found out that the guy before me smoked the clutch and tires after I rode it and before i went to get it BASTARD. What clutch should i use its stock with only k&n and PC pipes
thanks
  • 1 month later...
I'll second the Tusk kit. I put a set in my 250r and it worked great, its also dirt cheap. I think it was like $35 or somthing like that. Dont ask me how long it lasted because about a month after I put it in I hit a 660 grizzly head on in the trails and totaled the bike... sold it a week later. Grizzly only got a bent front bumper and rack.
thanks
448345[/snapback]
that's why it's important to take another ride before actually picking it up, and paying up. then you could have told the guy to shove it, or at least gotten a price reduction. lesson learned the hard way, right??
i'd go with the tusk kit. cheaper end of the market, but seems to be pretty dependable in a slightly mod'd shee. if your shee is decked out, you'll want to step it up to something else. B)
thanks
448345[/snapback]
i personally am running the vitoz clutch with the hinsion clutch basket and outer plate . I LIKE THE VITOZ clutch ALOT havent felt no signs of wear and i abuse the clutch alot and it just keeps on gripping !
  • 2 weeks later...
S :) tock plates with barnett springs.Stock plates has less surface area than some of the after market,Less surface area with stronger springs means it can not slip as easy.I broken plates from hooking up hard on black top before they slipped and burnt the fibers.Also the steels can warp from getting hot.If you dont put alot of stress on your clutch the cheaper kits do work fine. :)
stock clutch with the use of good oil like honda gear oil. I got 14 years out of my stock 1990 clutch & I spent most of my time down in the holes at the dunes ( heat feathering etc..) Most of that time it was swimming in honda gear oil. :rolleyes:
I used clutch fibers out of a yz490..........they are the same .....but are just much stronger!!!!!!!!!!!........3 stock springs / 3 barnett
trust me they work awesome :bolt::cheers:
barnett dirt digger all the way.dont be cheap(tusk).run the stock springs they give you with the dirt digger kit.i slip the hell out of mine hillclimbing.holds up great.those tusk cluthces will be slippin in a year.
