hi all i pulled out my plug after more than 5 hour of riding hard and this is the color of the plug in the pic .
and my setup is fmf-sst pipe C.v. 35mm single carb 225 main with EEK needle in #3 from top pilot 55 trinity head with 21cc dome 153 lb on both side clean up port job and boysene power reeds with ported stock reed cages and +2 advanced timing with GYT-R CDI and MSD coil with MSD wire and 15 tooth front spracket with 41 in the back .
445131[/snapback]
THE FIRST ONE IS TOO RICH AND THE SECOND ONE IS A BIT TOO LEEN
445290[/snapback]
I think they're the same plug, just the second one used the flash. From looking at the first pic, I would say its fine, although maybe a little on the lean side. Hard to tell from a pic exactly whats going on.
445131[/snapback]
445296[/snapback]
I agree, seems a touch lean but probably OK. Could raise the needle up one and see how that works. 225 main seems pretty heavy on the fuel though.
It really amazes me on how people read plugs....For one, normal riding will give you a false plug reading. So those pics are a waste of time...Two, put the plug back in and run in wide open in 6th gear for 5-10 seconds, pull the clutch in, shut it down, coast to a stop, then take a pic of the plug. Guaranteed it'll look a lot different....
Banchetta
i did i plug test with new set of plug i run it in 6th for 15 sec. pulled the clutch shot off the ignition pulled the plug out and what did i see is littel peaces of carbon on the plug with clear white color in the middle .
i tryed rising the needle one clip more and in bogs more before the power band and fouls plugs on low speed riding ?
Banchetta
445517[/snapback]
Put some run time on the plugs first. I hate using new plugs. Get them colored, then run it wot. Your pipes give max hp at 1200degrees. You won't hit that just cruising around which will have a darker colored plug since your exhaust temp is low...The ground strap on the tip of the plug is your temperature teller. Over 1350 degrees and pistons will start melting..at 1200 degrees you can get max hp and safely run it wot for long periods..run it again w/ those plugs now that they have color on them..
as for the needle, trial and error, find the best low end response. If it didn't like rasing, then try lowering...find the sweet spot.
Edited by Banchetta
445131[/snapback]
try the 4th clip and then lower your main some. and then do a plug chop. get a little more fuel in the mid and cut your main down some it should be a good runner
