face_off
Everything posted by face_off
so you think i should leave the holes with out modification and just match the top case to the bottom of the cylinder .
another pic of the same case .
hi all and i find theas pic. of case match and port but i didnt get it very will i mean do i have to drill the blocked holes open in blue color. and do i have to make the holes in red biger and do i have to re-angle it or leave it in stock angle but make it biger holes . and for the hole how big do i have to make it is thear any number should i use it .
hi all i use to have FMF-SST before i sold the pipe and buy a used LRD pipe and adjust the LRD pipe for the low power . from my test on the 2 pipes i felt that the FMF-SST has more power in the low end and the power band comes faster but the LRD has more top end than the FMF-SST . note : i like the performance of the LRD pipe its smoother than FMF .
its the same as the pic of the dome only on the right side and the left piston has some carbon in the middle only.
ScrewMachine i have single C.V. carb 35mm 2twin350s you think this caused off crank bearing and is it normal only one side of the engine have this marks on the piston and dome head ?
Banchetta i did i plug test with new set of plug i run it in 6th for 15 sec. pulled the clutch shot off the ignition pulled the plug out and what did i see is littel peaces of carbon on the plug with clear white color in the middle . i tryed rising the needle one clip more and in bogs more before the power band and fouls plugs on low speed riding ?
this problem is only on the right side and the timing is set to +4 and 96 octaine with mild head 148 lb on both side . the last blow up piston on the same side with the same small pits on the head dome and the piston was cracked and stick on the cylinder wall on the exaust side
hi all i pulled out my plug after more than 5 hour of riding hard and this is the color of the plug in the pic . and my setup is fmf-sst pipe C.v. 35mm single carb 225 main with EEK needle in #3 from top pilot 55 trinity head with 21cc dome 153 lb on both side clean up port job and boysene power reeds with ported stock reed cages and +2 advanced timing with GYT-R CDI and MSD coil with MSD wire and 15 tooth front spracket with 41 in the back .
hi all i open my engine last week and notes this problem and its after a fresh top end rebulid and after 4 weeks of rideing ? and is this caused of lean main jet or to much timing ?
over 28 veiws with not even one single replay to help me out ? why is my question so hard or what ?
what size of dooms for 96 and 98 octane ?
face_off replied to face_off's topic in Banshee Repairs and Mods
but if i add the 20cc domes my compresion will be above 160 is this right on stock crank not wilded ? -
is thear any one how can help me out ?
hi all and i would like to know what size of dooms i can use with ether 96 or 98 octane pump gas on my banshee my setup stock crank and 35mm cv carb +4 timing and fmf sst pipe and im at sea level with temp around 15c' to 25c' and hum. around 40 to 75 .
hi all i have some problem in my jetting . right now my setup is wood porting and mild stock head fmf sst pipe +4 timing lighted flywheel ported reed cages with boyseen power reed and CV35mm singel carb with clamp on filter and the jetting is 205 main with eek needle in 4th clip from top and 42 pilot with air screw set to 3.5 turn out . and it idels fine and rev out clean in nutrail and for the plugs after more than 3 hours riding they are wet with dark brown color in the midle and when riding it in the power band a round 1/2 throtle to 3/4 it runs clean and strong but from that position in the throtle to WOT it cut off and come back on and runs clean and hard in 5th and after shifting to 6th it cut off and come back on and runs strong to full WOT this problem happens some times not always . im at sea level with temp around 15c' to 25c' and hum. around 40 to 80 . and the other problem is bog before power band and fouling plug in low speed and bogging when crosing in this range 1/4 to 1/8 throtle . and when starting it cold it needs the choke to start and when it start with the choke on it idels higher than the choke is off and in warming up it louds up and one plug stop from runing and you have to rev it some times so it start again .
i install the msd coil on the stock cdi ignition and i notes good improve over stock . and i have a GYT-R cdi ignition and i will install it with it and try it out next weekend .
hi all and did any boddy used the msd coil with 8.5mm wire on stock banshee ignition with aftermarket CDI ? and how do the msd coil compaire to nology coil ? they said on MSD website that the coil preduce 30.000 volt is this true ! i have the msd coil and i will try it today and compar it to stock coil .
chevyboy51 how did you install the 8mm Taylor Sprio pros in your stock coil the stock wire are fixed in the coil ? can you send any pic of your coil after the mod you done in it and what did you use for the plug caps ?
from where i can get the hot wire any brand or website ? http://www.bansheehq.com/forums/index.php?...c=46603&hl=gytr
no lonestar you get me rong im not saying that your engine is advanced ! im saying that Ducman on other thread talking about the GYT-R CDI ignition has +3 timing over stock CDI so is this true or not ?
lonestar did you advance the timming with your setup or not ? Ducman : sayes on other thread that the GYT-R cdi advance the timing about +3 over stock .
hi all . i have the GYT-R cdi on my banshee and in the yamaha web site they say it gives hotter spark plug with good dyno chart bout my question is does it advance the timming or its a stock timming with only hotter spark plug and digital signal ?
i know that but what should i do the shipping coast is so high her and its cheaper to find some used ones with port job in them from USA and ship them to me .
hi all i would like to know does any one had any used banshee cylinder ported by Eric gorr for wood/trail ride with 404 kit in it that uses stock crank for sale ? or Eric gorr port job on stock cylinder with stock crank ? or Passion racing 12 ports MX port job for stock crank ?
hi all and im planing to port my banshee but im thinking of the racelogic templates but does any one know whats the difrance between the ( stage II Fast trail and the stage III superstock ) ? and for theas templates how do they compair to the MX porting and trails porting ? and i want super low end power with out lossing to much on the top my setup is : fmf SSt pipe C.V. 35mm +4 timing stock gearing ported reed cages with boysen power reeds stage IV head with 21 CC doom
