CadillacBanshee Posted December 4, 2005 Report Share Posted December 4, 2005 My friend rebuilt his engine and put 20cc domes in his coolheads. The compression went up to 185psi. The bore is 3 sizes over and the bike runs good on 91 octane. Is that too high for that bike? Will anything happen when runs 110 octane like he should be? One person in know blew his engine when he milled his head and raised his compression to 165psi and ran high octane. What should i advise him to do? (smaller domes maybe?) He wants to know if his engine will get messed up if he keeps that high compression. mod list: 320 Mains 4th clip needle t6's v-force 3 reed spacers no air box coolheads 13F/41R Engine Ice skat tracs Quote Link to comment Share on other sites More sharing options...
wesw Posted December 4, 2005 Report Share Posted December 4, 2005 you need 100 octane or better you could try some 100LL from your local airport. Quote Link to comment Share on other sites More sharing options...
hittintrees srh Posted December 4, 2005 Report Share Posted December 4, 2005 i'd use VP C12-just my .02 Quote Link to comment Share on other sites More sharing options...
sand rocket Posted December 7, 2005 Report Share Posted December 7, 2005 if his crank isnt welded, tell him to plan on another rebuilt!! Quote Link to comment Share on other sites More sharing options...
Dead Op Posted February 9, 2006 Report Share Posted February 9, 2006 Whats youe elevation at! 185 with 20cc domes! Quote Link to comment Share on other sites More sharing options...
Big Blue Posted February 9, 2006 Report Share Posted February 9, 2006 Whats youe elevation at! 185 with 20cc domes! 471246[/snapback] That is what I was thinking, sounds like your gauge might be off. Quote Link to comment Share on other sites More sharing options...
CadillacBanshee Posted April 5, 2006 Author Report Share Posted April 5, 2006 My elevation is 300' above sea level. I just put 21's in my bike and got only 155psi. Quote Link to comment Share on other sites More sharing options...
sandgrencivic2k1 Posted April 24, 2006 Report Share Posted April 24, 2006 That sounds about normal to be 155 psi. I had 19cc domes and was at 185 psi at 50 feet above sea level. He better run 110 fuel if he doesn't want to rebuild it again. Also you would not want to go to smaller domes. The smaller the dome the higher the compression. But I would check the gauge, cause 185 seems high even at sea level. Quote Link to comment Share on other sites More sharing options...
