I have one and have had it in since last spring with no problems. I put it in while I had my flywheel off. You just need to make sure you seat the key all the way properly. You really need your flywheel off to do this. And you would need to have your flywheel off to do the timing plate as well. Either way, I think it is a definate worthwhile mod.
where do you feel a difference...low,mid ,topend ... what does it do
442647[/snapback]
Low end. Don't go with the key though, just get a stator plate or mod your stock one. Way more reliable.
I had a +4 key in my cub motor when I lost my stock one(just to get me through the weekend) pulled the fly wheel to put the new stock one back in and the key was half sheaered off already! do a search on modding your stock timing plate and you can save your self $20 or if you don't feel comfortable doing this buy a ricky stator timing plate, they are only $35.00 friends of mine have bought the plates off of ebay as well. more timing is gonna get you more bottom end will sacurficeing a touch on top.
hope this helps
