It has a lot of safety switches that go bad and cause you to chase ghost. makes your carbs look ugly, added weight, makes your teeth go bad, and tells everyone that you're to stupid to take off the parking brake before you go riding. thats just off the top of my head, I could come up with more if you would like.
tors is heavy. you may not think it but any wieght you save is going to help. its definately worth it to take it off. its the throttle override system. if your throttle gets stuck it shuts your bike off i believe. the problem is, sometimes your throttle isnt stuck and your tors thinks it is. there are bad places for this to happen. being chased by godzilla comes to mind. :shrugani: leave it on if you want but youll probably take it off someday anyways.
i was chased by godzilla one time luckly i had taken mine off cause i heard while i was being chased that they had went out, could have been a close one but i did get away :cheers:
442662[/snapback]
see typhoon. shit happens. godzilla happens. good testimonial cb.
motion pro makes a kit, give you tops, new cables, and the idle screws, i think its like 60 bucks and is really easy to instal except for the fact that you have to drill the carbs!
443598[/snapback]
"drill the carbs"?
Actually into the carbs?
Thanks,
Alan
