i've got $250 and i was wondering where it should be spent, well of course the engine, but on what? And yes i did a search on this topic and most people narrowed it down to reeds or a coolhead/nosshead. I did have a question about the coolhead and nosshead, what is the difference in the two? So what should i spend the money, reeds, coolhead/nosshead?
Here's my setup
2000 banshee
T-5's
Hot Rods crank and wiesco pistons
clamp-on K&N's
+4 timing
lightened flywheel
and either a 310 or 320 main
Riding Style: Just general riding around, tooling around with buddies (they ride a 660 raptor, Z-400, and a KFX 400. I do like wide open top end runs, but i do ride trails any chance i get, just not real tight ones. obviously.
Thanks for the replies.
i concur..(that means i think this is a good idea as well) :D
438643[/snapback]
LOL..mr to I would go with v-force or get it ported..But I think you would be better off to get the V-forces and get the porting next time around..
Well i know for sure i don't want to make it a stroker, i shouldn't say don't want to, just can't afford it. But definitely no stroker, unless of course i get a little lonely and no one's around. Kidding, geez. I think i'll do the gorr port, what will i gain and what will i lose? Also if you got a gorr port tell me what you thought of it. Another question, will i be able to run the stock carb setup with this port? I plan on upgrading the carbs (bigger ones, 34's maybe) but that won't be till about april/mayish. How do i get a hold of this guy so i can find out some prices and info? Keep the replies coming, thanks.
438678[/snapback]
the porting is gonna run more than $250 most likely. there's shipping, gaskets, and probably new pistons, a hone job, possible bore.......
for a simple bolt on with no headaches or downtime, I'd put the reeds on, or save my money til I had enough for new pistons and such.
if you didn't care about the length of down time, you could sell your cylinders and probably pick a set of used ones that have been ported for a very similar price. the cubs have put a pretty large surplus of ported stock cylinders on the market. people that spent a grand on drag porting are selling their cylinders for nothing, because nobody wants them anymore in favor of the cub.
I realize that it will be a lil more than $250 but i shouldn't need a rebuild, about a year ago i rebuilt it with weisco's and a hot rods crank. But in that years time i've ridden the banshee probably twenty five or thirty hours. And yes i realize i will need to get new gaskets but i actually think i might have some laying around. What do you think?
porting is gonna give you the most bang for the buck if you take the cylinders of i would at least hone them and get new rings :shrugani: if $250. is your budget i would get the stock head shaved 30 thou. with the left over $$$ i would get some race fuel you might need it with your +4 timing
