compose2 Posted November 9, 2005 Report Posted November 9, 2005 i just ordered my longer rod stroker kit. went with the +4mm. while this is ordered i decided to bore my cylinders from stock to .040 over. i have a bunch of other stuff already such as t5's, vforce reeds, milled head, timing advanced..... all that stuff. my question is, going from stock bore and stock stroke to 4mm longrod stroker with .040 overbore, should i see a huge difference once its all back together? top, mid, or bottom? Quote
wayfst Posted November 9, 2005 Report Posted November 9, 2005 no, not without the proper porting, choose wisiely you only get one shot at it. Quote
BdBanshee Posted November 9, 2005 Report Posted November 9, 2005 I recommend you don't skip any bore sizes, unless your just made of money......... Quote
compose2 Posted November 9, 2005 Author Report Posted November 9, 2005 i do have a port and polish job already done to my banshee as well. its got tons of power.i am just looking for more bottom end. i figured a stroker would help out Quote
compose2 Posted November 9, 2005 Author Report Posted November 9, 2005 i was thinking of eventually going to cheetah cubs next year or a monoblock setup anyways Quote
fast87 Posted November 10, 2005 Report Posted November 10, 2005 i'd just wait for a monoblock/cheetah setup...also don't skip bore sizes like what was said above, never ever ever ever bore your cylinders to gain power, always always always bore the minimum amount, just enough to clean up the scratches in the cylinder walls...for obvious reasons ~Mark~ Quote
ogre03 Posted November 10, 2005 Report Posted November 10, 2005 Aren't there issues with putting a long rod stroker kit on previously ported cylinders? Quote
fast500#12 Posted November 10, 2005 Report Posted November 10, 2005 (edited) yes. you need to talk to who ever did your port work and see if it is compatable. stoking your motor changes your port timing and some port jobs wont work with a stoker kit. Edited November 10, 2005 by fast500#12 Quote
