banshee tuner Posted November 7, 2005 Report Posted November 7, 2005 I've got a fresh top end cause it was not running proper and with original top end and low uneven compression I figuered it would not help. I now have good even compression and right cylinder still has very little exhaust and exhaust is cold. Bike is running off left cylinder and runs awesome if you can make it to top end, but bottem end sucks. What would be the cause electrical if swapping plug wires has no effect and problem remains on right cylinder. Right plug is wet and getting fuel and reeds swapped between cylinders makes no difference. Quote
BansheeBillyBob Posted November 7, 2005 Report Posted November 7, 2005 u got spark on that side? Quote
smokincycles Posted November 7, 2005 Report Posted November 7, 2005 i had the same problem,,,my crankseal was bad,,,,right side plug had a slight gear oil smell,,,i had one cold pipe so i swapped parts with a buddy untill crankseal was only thing left,,,problem solved Quote
Wallrat Posted November 7, 2005 Report Posted November 7, 2005 Yes you can swap plug wires with no ill affects. Quote
banshee tuner Posted November 7, 2005 Author Report Posted November 7, 2005 Checked plug and don't have gear oil smell, swapping plug wires has no effect. Since both fire at the same time is it possible to get fire when left piston is at top dead center and not when the right piston is at the top. Like if it only triggers to fire at one position of the flywheel and not 180 degrees around. Quote
NEVER SATISFIED Posted November 8, 2005 Report Posted November 8, 2005 (edited) clean your pilot jet!!! get you a small needle and poke it!! o forgot... also check your reeds... Edited November 8, 2005 by NEVER SATISFIED Quote
banshee tuner Posted November 8, 2005 Author Report Posted November 8, 2005 I have been through the carbs and can see through the jets, I have swapped reed cages from one cylinder to the other and I am pretty sure it is a firing problem. Does anyone know if this could be the stator, cdi, or possibly flywheel causing this. Quote
smokincycles Posted November 9, 2005 Report Posted November 9, 2005 IM STILL LEANING TOWARDS CRANKSEALS AND MAYBE EVEN A BAD CRANK ONCE YOU GET IT APART...THIS IS WHAT MINE DID...ONE PIPE STAYED COLD....REVVED LIKE A BLASTER... NOBODY WANTS THAT...IT EVEN CHANGED SIDES ON ME AND THE OTHER WAS HOT AND THE HOT ONE QUIT FIRING...NO MATTER WHAT I DID SHE WOULDNT RUN RIGHT...IT EVEN RAN ON EACH CYLINDER ONE AT A TIME WHEN ONE PLUG WIRE WAS OFF THE OTHER SIDE......HAD ANOTHER 01 BANSHEE TO TROUBLESHOOT WITH SO I CHANGED COIL-CARBS-REEDS-CDI BOX-STATOR-REMOVED THE TORS-REMOVED PARKING BRAKE-RAN IT WITH NO SILENCERS-PULLED THE JUG TO INSPECT THE COLD SIDES PISTON-SO WHAT WAS LEFT--RIGHT,,,,GET THE GUN OUT AND KILL IT....SO I WAS CHANGING THE CRANKSEALS AND FOUND I HAD A SLOPPY CRANK TO ADD TO MY MISERY....PUT IN A USED CRANK AND NEW SEALS AND SHES A SHEE AGAIN....RIPPIN LIKE IT WAS NEVER BROKE....IF IT KINDA SOUNDS LIKE THAT TRUE LITTLE STORY I JUST BORED EVERYONE WITH TEAR IT DOWN,,,PUT NEW SEALS IN IT AND GET AN OPINION ON THE CRANK WHILE ITS OUT....DONT FORGET TO GET SOME YAMABOND FOR THE CASE HALVES Quote
banshee tuner Posted November 9, 2005 Author Report Posted November 9, 2005 Mine never changes sides, it is always the right side that does not get hot. If I pull the right plug wire it will run, if I pull the left it will not run. If it is a crank seal wouldnt I be loseing gear oil. Quote
NEVER SATISFIED Posted November 9, 2005 Report Posted November 9, 2005 (edited) yeah you'd be loosing oil... so you swap plug wires and it stays on the same side... thats not right... if its electrical it would follow the electrical current.. sounds to me like your rings didnt seet... possible air leak... have you pulled the plug and just tried crankin it over to see if you get spark... i had good compression in my cylinders but when it ran i had a leak someplace and it ran for shit! Edited November 9, 2005 by NEVER SATISFIED Quote
Shee_Rookie Posted November 9, 2005 Report Posted November 9, 2005 Damn this brings back recent memories. I had the same thing happening and I was thinking it was reeds or air leak. Turned out to be the parking brake... The damn thing was released but the whole p-brake assembly was moved down. Fixed that and no more probs. Quote
banshee tuner Posted November 10, 2005 Author Report Posted November 10, 2005 Parking brake is gone and tors. It was doing this before the rebuild and I rebuilt because the compression was uneven from one cylinder to the next. Now I have good compression and the same problem before rebuild. When it is kicked over it has fire but unsure if it is enough. I'm going to take resistance readings on stator and follow the manual for any other specs. Quote
NEVER SATISFIED Posted November 10, 2005 Report Posted November 10, 2005 check that current... goood troubleshoot!!!!... you might be correct and not be gettin enough current .. although it would switch sides if its electrical... Quote
tripledsracing Posted October 19, 2006 Report Posted October 19, 2006 check that current... goood troubleshoot!!!!... you might be correct and not be gettin enough current .. although it would switch sides if its electrical... im having same problem my plug has fire also but right cylinder not firing,i started it one day and it screamed let it set for a while went back to start it and it started missing on the rightside weve checked everything we could still nothing tore it down and the rings and piston is perfect,well the only thing i can think of is the stator we changed the flywheel and the crank seals after that this problem started the day we done it,it was very hard to start but when it started it missed on the rightside for just a minute then both cylinders were firing normal but each day it kept getting worse,ive read every post on this site and planet sand and the same oh stuff check your plugs,swap carbs,swap reeds,check caps,check stator,air leak,crank seals ive tried it all so know im gonna put new rings and pistons and try that hope to god it works but i doubt it hope you find out for both are sake thanks if i can help just email me at [email protected] or pm me on here or planetsand my screen name is the same Quote
akita8 Posted October 19, 2006 Report Posted October 19, 2006 Make sure your slides in the carbs are adjusted exactley the same. Quote
