does any1 kno if u have 2 take off part of the swingarm to replace 1 of the chain rollers its the 1 at the top next 2 the fatty bolt that goes through the arm if that made any sense :blink: Also the roller got worn down and there is grooves worn in 2 the arm from the chain would this affect the roller when i replace it?
Edited by BitchesGetStitches
Yeah you do, so make sure your bearings are looking good at the same time.
The swingarm bearings are not machine pressed in.The stock swingarm roller sucks,go with the upp slider.You probably want to buy a new chain,I bet you old one is FU*KED
