Mxzdan Posted October 12, 2005 Report Posted October 12, 2005 I called Yamaha because I need two exhaust clamps they told me 80 buck cdn Is there anything else you could use and where to get it I dont feel like paying 80 bucks for a little peace of hose Quote
Polish Posted October 12, 2005 Report Posted October 12, 2005 I called Yamaha because I need two exhaust clamps they told me 80 buck cdn Is there anything else you could use and where to get it I dont feel like paying 80 bucks for a little peace of hose 425374[/snapback] WTF .......is a clap Quote
macgillivary Posted October 12, 2005 Report Posted October 12, 2005 (edited) the rubber piece connecting the 2?? just go to a plumbing shop and get some red rubber, heat resistant, youll pay under $3 for what ya need plus 2 hose clamps for each side, not the sexiest but does the trick Edited October 12, 2005 by macgillivary Quote
hittintrees srh Posted October 12, 2005 Report Posted October 12, 2005 Dude look at ebay. theses a million differant styles for a shit load less than $80 For god sakes there just clamps!! Quote
Mxzdan Posted October 13, 2005 Author Report Posted October 13, 2005 the rubber piece connecting the 2??just go to a plumbing shop and get some red rubber, heat resistant, youll pay under $3 for what ya need plus 2 hose clamps for each side, not the sexiest but does the trick 425379[/snapback] Yes the rubber pieces connecting the pipes to the silencers I went to napa and they told me they had noting that would work went to the hydralic shop and they also told me they had nothing that would work frig might have to buy some from yamaha thanks dan Quote
ke398 Posted October 13, 2005 Report Posted October 13, 2005 If it aint a show quad, as mentioned above, automotive heater hose and 2 hose clamps work great. Quote
kenr74 Posted October 13, 2005 Report Posted October 13, 2005 Check out these clamps on ebay. http://cgi.ebay.com/ebaymotors/YAMAHA-BANS...1QQcmdZViewItem I have a used set I'll ship you for $30 if you want them. They are missing one screw so you would just need to replace that. The hose is red not black. PM me if you are interested. Whatever you do DON"T pay $80 for those stock ones. Quote
banshdog Posted October 13, 2005 Report Posted October 13, 2005 What kind of pipes do you need them forr? stock? Quote
Ducman Posted October 13, 2005 Report Posted October 13, 2005 Get a set of pipe seals like the ones sold by chosenperformance.com Quote
kracker2k Posted October 13, 2005 Report Posted October 13, 2005 I just recently had this delema with my banshee. All I did was go to Autozone and ask too go in the back and found some high temp radiator hose that fit what I needed. Got a piece that was l shaped and about 12 inches long. Got this for about $5 and then bought eight hose clamps for about $0.50 each. I used some clipper things for hedge trimming to cut the hose into 5 pieces thowing away the angled piece and then I put it on. Ended up about $11 after tax for everything. Worked great and was cheap. Might want to try this. Take the small piece of exhaust with you and tell them you need some hose that pits snug on there and you should find something. Quote
Mxzdan Posted October 13, 2005 Author Report Posted October 13, 2005 What kind of pipes do you need them forr? stock? 425646[/snapback] yepp it's for stock pipes will go to napa and ask them for Quote
Polish Posted October 13, 2005 Report Posted October 13, 2005 yepp it's for stock pipeswill go to napa and ask them for Quote
kracker2k Posted October 17, 2005 Report Posted October 17, 2005 How was your luck with the method I proposed? Quote
