I called Yamaha because I need two exhaust clamps they told me 80 buck cdn
Is there anything else you could use and where to get it
I dont feel like paying 80 bucks for a little peace of hose
:cheers:
:cheers:
425374[/snapback]
WTF .......is a clap :yank:
the rubber piece connecting the 2??
just go to a plumbing shop and get some red rubber, heat resistant, youll pay under $3 for what ya need
plus 2 hose clamps for each side, not the sexiest but does the trick
Edited by macgillivary
425379[/snapback]
Yes the rubber pieces connecting the pipes to the silencers
I went to napa and they told me they had noting that would work
went to the hydralic shop and they also told me they had nothing that would work
frig might have to buy some from yamaha
thanks dan
I just recently had this delema with my banshee. All I did was go to Autozone and ask too go in the back and found some high temp radiator hose that fit what I needed. Got a piece that was l shaped and about 12 inches long. Got this for about $5 and then bought eight hose clamps for about $0.50 each. I used some clipper things for hedge trimming to cut the hose into 5 pieces thowing away the angled piece and then I put it on. Ended up about $11 after tax for everything.
Worked great and was cheap. Might want to try this.
Take the small piece of exhaust with you and tell them you need some hose that pits snug on there and you should find something.
What kind of pipes do you need them forr?  stock?
425646[/snapback]
yepp it's for stock pipes
will go to napa and ask them for
