just got a set of cylinders off ebay ported my question is i've seen porting with boost ports on bottom of intake but the cylinders i have has them on top too. so they have 4 boost ports per cylinder. any one heard of this before? i will post pic"s as soon as i find my camera. please any info thanks
Ive seen this mod on stock Banshee cylinders. Also, CT does this on their aftermarket Blaster cylinders along with the triple ex. ports. If everything else is in order, it should RIP...Jim
Thanks for the info, (I couldn't post any pics,I kept getting an error message saying that the file was too big.) I've never seen that done before- the top boost ports go straight thru to the xfer port, nearest the exhaust, without cutting into the xfer port that the bottom boost port goes into. Thanx again. :cheers:
425807[/snapback]
send me the pics, i can post them for you. im intrested in seeing this.
[email protected]
Not too sure what "boost ports" really are  :confused:
Can someone fill me in? And post those pics.
I wanna Know more!!
425999[/snapback]
Here's a pic of the cubs, you can see the boost ports to the far right and far left of the main intake port.
Those are not boost ports those are boyesen ports. Boost ports are the small port above the intake port on stock cylinders.
426071[/snapback]
Sounds like the cylinders he is buying have 2 boyesen ports and 2 boost ports per cylinder.
Do Boost ports really do anything?
all i have to say is
THAT IS THE HACKEST PORT JOB IVE SEEN.
wow looks awful to me
but shit it might run who knows :shrugani:
I would not run that shit if it was me...It looks like he freaked up the boysen ports and resleved the cylinders?
is there any material between the boysen port and the seleve wall? Hell is there even any sleve left where he bored the hole?
from the pics it looks like the cylinders are not even runable cause it looks like the piston ring will catch where he freaked up the boysen port.
Edited by Justintoxicated
