t.spraker
Everything posted by t.spraker
  1. look's like i got freaked on ebay. anybody want a boat anchor? i guess i am going to get an eric gorr woods port. (what i wanted anyway's) good thing it was only $65 or i'd really be pist. thanks for the info. you guys are great.
  2. email sent.
  3. Thanks for the info, (I couldn't post any pics,I kept getting an error message saying that the file was too big.) I've never seen that done before- the top boost ports go straight thru to the xfer port, nearest the exhaust, without cutting into the xfer port that the bottom boost port goes into. Thanx again.
  4. just got a set of cylinders off ebay ported my question is i've seen porting with boost ports on bottom of intake but the cylinders i have has them on top too. so they have 4 boost ports per cylinder. any one heard of this before? i will post pic"s as soon as i find my camera. please any info thanks
  5. make sure your pickup coil is .020 from your flywheel same thing happened to me. good luck.
  6. have you done a compression test?
  7. will i have any problems with this bolting up to to the vforce because the reeds have that raised center and the intake is flat. anything i need to know? any help would be great thanks.
  8. anyone have an extra set? or is there a place that would have that kind of stud? hardware store ect? thanks a lot for any help.
  9. #3978493 is the casting numbers on the heads. the intake edelbrock performer RPM. looking for an 2 into 1 intake,aftermarket head,lightened flywheel,paul turner mids,a arms,anything to make a faster,better handling shee. let me know what you have thanks.
  10. I want to trade smallblock chevy street\strip parts for aftermarket shee parts. I have 2.02 heads,1.6 roller rockers ,7\16 screw in studs,3\8 screw in studs,2 sets of guide plates,.100 longer pushrods,TRW dome piston's 0.030 used only three passes,850 cfm raced preped holley carb,milodon main caps never installed, proformer rpm intake brand new,there's more just ask and i will see if i have it. also have tons of stock parts too. thanks
  11. anyone know anything about this any good for trail riding?
  12. i have an 03 shee with just pipes and vforce 3's im at around 1000 feet elavation i checked the compression yesterday and it was at 100 psi is it time for a rebuild? any help would be great thanks.
  13. i just got a new set of vforce reeds. i have to cut off the tabs of the intake i have the instructions my question is won't a hack saw screw up the mating surface between the reed and intake. does anyone have any better ideas thanks for any info.
  14. anyone know where i can find one ?
  15. im going to get a filter now
  16. where should i start with neadle thanks
  17. i live in up state ny not sure my elavtion with graydon proline pipes with the air box lid off stock filter (soon to have k&n in box filter)the temp. is about 75 to 85 mainly anyone know where to start?
  18. Anyone heard of these and know any info?
  19. Has any one got any info. on graydon proline pipes ? or know were i could get some info......
  20. The thing is that this was dence white smoke that smelt like something melting down just out of the right side. has anyone heard anything about graydon pipes?
  21. This past weekend i put on graydon proline pipes. Switched from 240 main jet to 310 figered start out rich. Went out for a half hour to warm then ran about an 1\8 mile WOT and shut down smelt funny then i seen smoke from right cylinder. kicked over slow and smoke poured out i let it cool ckecked the plug looked to be kind of dark started it back up and it ran fine w\no smoke. any help please!
