I had mine painted andn now they are powdercoated. Either way is find. Although painting is cheaper, it does take many coats to ensure coverage on the inner part of the rings. Paint won't chip, if you take your time with it. It's a difference of about $50 and some of your time. You make the choice.
That was what I thought at first, and then I was told that powder coating is baked on at only 400 degrees, like what you cook your turkey dinner at. I don't think it would have any affect on the spring rate.
Actually that's pretty hot. No its not anywhere near melting point, but I'd be amazed if you didn't see some changes in the characteristics of the spring. I pm'd DUNEDEMON this thread, hopefully he'll chime in. That guy knows just about everything there is about springs after having been in charge of R&D at eibach.
PC is fine as long as they dont bake the old PC or paint off. 400deg F or so you're fine, will not affect the springs charistics. Coat them and be done with it already, not that big of a decision.
430304[/snapback]
Like what I said..
430304[/snapback]
Ok ok I'll powdercoat them, dang, I just wasn't sure if pc was flexable enough for springs. Thanks for the advice! :)
