everyone's gonna tell u NOSS heads. i got a pro design myself cas i got a great deal on it at a dealership since it sat there a year new in the box with 2 sets of domes. but next time round i'm goin to dave. nice work plus his fit stock studs (if urs was stock ). all n all he's the man to talk to!
Definitly Noss! You may want to talk with dave and have him custom cut some BB domes for you. Depending on your porting you may want your domes cut for more top/mid/low end rather than a generic one size fits all cut. He has a HQ member discount and his annodized colored heads looks really nice. Using your stock studs is a big + with noss heads as well.
how about this don't get a trinty head, the head works awsome for really extreme stuff, but for yours anything else. they just really over though it and it is a pain in the ASS to put together. just my opinon I could be wrong.
is an aftermarket head just a bolt on procedure? What else is necessary for installation?
It installs in an hour or two. No other mods are necessary if you keep the compression under around 180 psi. It's a good idea, as with any mod, to check jetting afterwards but the jetting doesn't usually need to be changed. It's a quick, easy, relatively inexpensive mod for the difference it makes.
I was also wondering about the NOSS head, if you change dome size will it effect jetting? Also what is the stock dome size?
Jetting usually doesn't change with a different dome size but I always recommend checking it with any mod (or season change). The stock chamber size is 22cc to 23cc.
