racer Posted August 9, 2005 Report Posted August 9, 2005 i think it lasts pretty long. a guy i know who rides the local 250 expert class changes the topend in his cr250 every season. the bike is like a 98 and still runs fuckin hard. of course its been well taken care of, but when hes in a moto that thing is gettin fuckin ripped on. Quote
alcoholbanshee Posted August 9, 2005 Report Posted August 9, 2005 I have an arctic cat snowmobile that has 6500 miles on it. The bore has never been recoated! In a related story my cub motor had as catastrophic of a meltdown as anything i've ever seen. I could stick two fingers thru the hole in the piston! There was no damage to the bore whatsoever! There was aluminum everywhere but the bore was fine. I guess the moral to the story is nickisil is some really tough shit. Quote
Cotton eyed Joe Posted August 9, 2005 Report Posted August 9, 2005 I have an arctic cat snowmobile that has 6500 miles on it. The bore has never been recoated! In a related story my cub motor had as catastrophic of a meltdown as anything i've ever seen. I could stick two fingers thru the hole in the piston! There was no damage to the bore whatsoever! There was aluminum everywhere but the bore was fine. I guess the moral to the story is nickisil is some really tough shit. 402834[/snapback] Thats fuckin amazing!!! There is a shop here that does it, but after a buddy of mine did the engine in his drag car....I don't know if I can afford it from that shop. Quote
locogato11283 Posted August 9, 2005 Report Posted August 9, 2005 I have an arctic cat snowmobile that has 6500 miles on it. The bore has never been recoated! In a related story my cub motor had as catastrophic of a meltdown as anything i've ever seen. I could stick two fingers thru the hole in the piston! There was no damage to the bore whatsoever! There was aluminum everywhere but the bore was fine. I guess the moral to the story is nickisil is some really tough shit. 402834[/snapback] well thats good to know. tough shit sounds like it.. Quote
RNBRAD Posted August 10, 2005 Author Report Posted August 10, 2005 well thats good to know. tough shit sounds like it.. 402921[/snapback] Sure is, now they need to coat the pistons with it too. Stuffs prolly too heavy. Quote
23champ Posted August 10, 2005 Report Posted August 10, 2005 If taken care of properly the plating will prolly outlast the quad. I've been riding mx bikes all my life. Trust me, I run them hard too but, I also take good care of my bikes. I clean the air filter berfore every ride, and after I get done ridding the first thing I do is wash my bike. My bikes are always clean. All motocross bikes have had plating since the late 80's. The only way to wear a cylinder(thats plated) out is by not overhauling your bike when its time. The piston starts to wear,and then begins rocking at the top of the stroke and at the bottom, this starts to wear at the coating. So if you want your CUBs to last TAKE CARE OF THEM! ED Quote
Master of Faster Posted August 10, 2005 Report Posted August 10, 2005 I'm a big fan of nikisil too. I have a Vmax-4 snowmobile with nikisil cylinders that has 11,700 miles on the original bore/pistons/rings. Has lost less than 5 psi per cylinder since the day it left the factory in 1992. All I do with the sled now is drag race, it spends all of its life at 8,500+ rpms without a problem, its amazing stuff. Here's an interesting tidbit, Vmax-4 750 and 800 nikisil cylinders will bolt on to Banshee cases. Banshee 400 with stock Yamaha cylinders Never tried it myself, but I beilieve its been done. Quote
racer Posted August 10, 2005 Report Posted August 10, 2005 MoF: so do these motors have basicly the same crank with a longer stroke? or how is this done? Quote
Master of Faster Posted August 10, 2005 Report Posted August 10, 2005 Vmax-4 800 cylinders are 65mm bore. Vmax-4 stroke is 59.6mm, 5.6 mm longer than a stock Banshee crank. So I don't know what the best way would be to go about doing it. Maybe a 4mil stroker Banshee crank and deck the cylinders? 7mil crank and cut the domes? These cylinders make some pretty wicked power, Vmax-4 800 with pipes is 170 hp. It's deffintely something I'd like to try, but I need to research it further. Quote
23champ Posted August 12, 2005 Report Posted August 12, 2005 How many cylinders are on that sled? Quote
GYTWYPT Posted August 13, 2005 Report Posted August 13, 2005 I know I know. Maybe some Mantoon billet cases to go with it. 401776[/snapback] whoa whoa whoa what are these mantoon billet cases all about and where can i see/get some. Quote
locogato11283 Posted August 13, 2005 Report Posted August 13, 2005 whoa whoa whoa what are these mantoon billet cases all about and where can i see/get some. 404360[/snapback] them mofros are expensive as fuck... Quote
reded Posted August 14, 2005 Report Posted August 14, 2005 The bling factor is off the hook tho! Quote
locogato11283 Posted August 14, 2005 Report Posted August 14, 2005 The bling factor is off the hook tho! 404574[/snapback] very true. i saw some in person down at GT performance one day..they were on a 24mm 800cc motor... Quote
