strokersquid Posted July 30, 2005 Report Posted July 30, 2005 just bought a long rod stroker crank on ebay new. box says .04 and rods are clearly longer than the stock hot rods crank i have but how do i know its a stroker ?the webs have the same #s written on them as the stock webs but the rods do have different #s than the stock hot rod crank. Quote
bkabina Posted July 30, 2005 Report Posted July 30, 2005 Measure from the center of the crank to the center of the lower rod pin(the bigger one).Do a crank you know is stock and then the new one. Quote
fixitrod Posted July 30, 2005 Report Posted July 30, 2005 (edited) If it's a wiseco they are pink in the center. That's how you know when to stroke her. Edited July 30, 2005 by fixitrod Quote
locogato11283 Posted July 30, 2005 Report Posted July 30, 2005 If it's a wiseco they are pink in the center. That's how you know when to stroke her. 398935[/snapback] haha pink in the center.. Quote
strokersquid Posted July 31, 2005 Author Report Posted July 31, 2005 it is pink in the center but so is the stock one. i just figured out though the webs are the same the stroker crank pin is further out on the web. the difference between the web end and the end of the pin is different between the two and the strokers is .09" closer to the web end x 25mm/in = about .2mm x2 per stroke = about .4mm or thereabouts. on this site i saw a crank with a blue mid thingy and i thought this signified a stroker. Quote
endofitall9 Posted July 31, 2005 Report Posted July 31, 2005 been there before, the rods will clearly be longer but the hard part is figuring what size stroker it is, if you don't know, i got the same replies from vito;s and wiseco about how to figure out what size stroke. "read the label on the box" "it takes a vanier caliper to measure it"...........good luck Quote
Rare Scottish Tree Badger Posted July 31, 2005 Report Posted July 31, 2005 ... the difference between the web end and the end of the pin is different between the two and the strokers is .09" closer to the web end x 25mm/in = about .2mm x2 per stroke = about .4mm or thereabouts. 0.09" (ninety thou') = 2.286mm Rare. Quote
racer Posted July 31, 2005 Report Posted July 31, 2005 0.09" (ninety thou') = 2.286mm Rare. 399104[/snapback] oh rare, you and your math. lol thats nine hundreths. but it looks to be a 4mm stoker crank. also you can identify the rods by the numbers on the side. stock stroke and rod is a model H100 stock stroke 5mm longrod is H114 4mm stroker longrod is H129 Quote
Rare Scottish Tree Badger Posted July 31, 2005 Report Posted July 31, 2005 oh rare, you and your math. lol thats nine hundreths. 399129[/snapback] Is that like ... nearly a tenth? Rare. Quote
Cotton eyed Joe Posted July 31, 2005 Report Posted July 31, 2005 oh rare, you and your math. lol thats nine hundreths. but it looks to be a 4mm stoker crank. also you can identify the rods by the numbers on the side. stock stroke and rod is a model H100 stock stroke 5mm longrod is H114 4mm stroker longrod is H129 399129[/snapback] Hey now.... 9 hundredths to me is .00009 .09 to a machinist is 90 thousandths. Its all the same. We just reference thousandths rather than inches. Quote
strokersquid Posted July 31, 2005 Author Report Posted July 31, 2005 thanks for telling about the # on the rod. if i had known that before, i wouldnt have to measure it indeed says 158 on the rods Quote
strokersquid Posted July 31, 2005 Author Report Posted July 31, 2005 it says h129 on the box, the question was how could you tell the crank inside was actually a long rod stroker crank and not just a long rod crank. its hard to measure the thing with only a basic slide caliper type micrometer but the results are close enough to tell me its a 4 mm stroker Quote
