i got .0030(.076mm) wiscos..
what size bore are they or is that stock size?? the kit was for stock size but the fit tighter then my last 1s witch might be better for me.. considering i prob needed bore..
thanks devin..
391728[/snapback]
That's the clearance that needs to be figured in for boring, not your piston size. ... If you're looking on the box, then it's the last four numbers on the above line. eg: 513M06500 are 65mm pistons (6500).
Rare.
I didn't even think the machine shop would bore your cylinders without having the pistons?
392893[/snapback]
If you go to the wrong place, they will happily take your money and send you on your way. Besides, if it's not the right bore size, you'll have to go back and spend more money. :confused:
I always have pro take a look at the cylinders, tell me what they think I'll need. Order the pistons. Hand the pistons and cylinders to the machinist and let him match them up.
392897[/snapback]
exactly,any well respected place will tell you thats the ONLY way to go
