discobanshee Posted May 31, 2005 Report Posted May 31, 2005 (edited) :dance:ok 30 pds is a bit to much how about a nice 5lb loss or bolt on that saves weight Edited May 31, 2005 by discobanshee Quote
badshee98 Posted May 31, 2005 Report Posted May 31, 2005 take your front brakes off. get a chromoly swingarm with a honda-style carrier(good for @12-15 lbs on my bike) get a cutting tool and start cutting off any brackets you aren't using. take off the front bumper take off the grab bar take your lights off Quote
demonspeeding42069 Posted June 1, 2005 Report Posted June 1, 2005 get light weight axle rims and tires this will cut off alot of poundage light weight rims (cut) and light weight sand tires cut front rims take off coolant rezzy take off all electrical junk u dont need lights, turn key , brake light , ect... if u are over weight like me try trimming down a lil that would be the easiest way lol Quote
discobanshee Posted June 1, 2005 Author Report Posted June 1, 2005 thanks for the imput,i think ill try the bumper nand grab rail first thanks again , matt Quote
discobanshee Posted June 1, 2005 Author Report Posted June 1, 2005 [thanks i could also lay back on the beers and then ill go faster,,hmmm maybe! Quote
discobanshee Posted June 1, 2005 Author Report Posted June 1, 2005 thanks for the axle idea!!! ill try it Quote
discobanshee Posted June 1, 2005 Author Report Posted June 1, 2005 ok the truth comes out my neighbor has a 450 yamaha it weights 30 pds lighter than my banshee and it hauls butt,i need to spank him next time we go to pismo. so ill buy a lighter axle loose my grab bar and fnt bumper and coolant res and ill go on adiet just lite beers will i spank him?? i kniow i do have him at top speed because hes only got a 5 spd comments or sugges tions Quote
demonspeeding42069 Posted June 1, 2005 Report Posted June 1, 2005 what mods do u have now? along with the axle i would go for the lite rims and tires... i picked up a regular sand tire on douglas rim then i picked up a super lite tire with lightened rims big difference like 2-3 lbs http://www.jimssandtoys.com/tires/tires.htm Quote
discobanshee Posted June 1, 2005 Author Report Posted June 1, 2005 whats on my banshee now 1996 rebuilt motor with fmf gnarly pipes and fmf jets and a boost bottle aluminum rims all arount skat trac paddles,i just want to spend wisely and i know there is normally abunch of weight to lose if you replace the right parts like pipes i lost atleast 15 lbs over stock,thats useable hp im thinking my bioke weighs around 365 stock is 386 but more needs to come off then add maybe some biyseen reeds???or is there some better ones to use. Quote
banshdog Posted June 1, 2005 Report Posted June 1, 2005 Did you drop parking brake crap and TORS? Quote
badshee98 Posted June 1, 2005 Report Posted June 1, 2005 for a budget lighter axle, get a 03 and up Blaster axle. Goes right in the stock carrier. as far as not drinking beer, going fast ain't THAT important. You could just swerve at him... Quote
ellison445 Posted June 1, 2005 Report Posted June 1, 2005 The price you will spend on a axle,rims & tires you might as well just get a port job...Then you will smoke him for a budget lighter axle, get a 03 and up Blaster axle. Goes right in the stock carrier.as far as not drinking beer, going fast ain't THAT important. You could just swerve at him... 376263[/snapback] Quote
bigboybanshee Posted June 1, 2005 Report Posted June 1, 2005 If the 450 has a pipe and filter; jetted properly and he is a good rider...he'll probably beat you if all you have is a pipe and boost bottle. You're gonna need more than shaving a few pounds here and there. Take ellison's advice, get a port job, probably cheaper than buying the wheels and axle and you'lll notice a BIG difference in power. Quote
discobanshee Posted June 2, 2005 Author Report Posted June 2, 2005 (edited) thanks for the advice hmmm i wounder if i tear down the top end maybe i should put on a cool head and bigger carbs?? or will my current stock carbs do the job i do have a set of smooth bore minukis ? 32 s plus i can still enjoy a cold one!!!thanks every one for your input!! Edited June 2, 2005 by discobanshee Quote
