discobanshee
Everything posted by discobanshee
  1. thanks for the advice hmmm i wounder if i tear down the top end maybe i should put on a cool head and bigger carbs?? or will my current stock carbs do the job i do have a set of smooth bore minukis ? 32 s plus i can still enjoy a cold one!!!thanks every one for your input!!
  2. whats on my banshee now 1996 rebuilt motor with fmf gnarly pipes and fmf jets and a boost bottle aluminum rims all arount skat trac paddles,i just want to spend wisely and i know there is normally abunch of weight to lose if you replace the right parts like pipes i lost atleast 15 lbs over stock,thats useable hp im thinking my bioke weighs around 365 stock is 386 but more needs to come off then add maybe some biyseen reeds???or is there some better ones to use.
  3. ok the truth comes out my neighbor has a 450 yamaha it weights 30 pds lighter than my banshee and it hauls butt,i need to spank him next time we go to pismo. so ill buy a lighter axle loose my grab bar and fnt bumper and coolant res and ill go on adiet just lite beers will i spank him?? i kniow i do have him at top speed because hes only got a 5 spd comments or sugges tions
  4. thanks for the axle idea!!! ill try it
  5. [thanks i could also lay back on the beers and then ill go faster,,hmmm maybe!
  6. thanks for the imput,i think ill try the bumper nand grab rail first thanks again , matt
  7. :dance:ok 30 pds is a bit to much how about a nice 5lb loss or bolt on that saves weight
