Last week i started up my banshee and the damn bike acted like it had a rev limiter it wouldnt rev over 600 rpm. I searched this site and asked someone about this problem and i got the same answer everywhere that my stator was most likely the issue. i got a rick stator stator and a new pickup coil and it dident fix the problem!
i have fooled around with everything trying to fix it the carbs i cleaned and tryied diffrent jets, i checked and cleaned my reed valves, looked over the entire electrical system to see for damaged wires, with this new stator i played with the timing, trryied new plugs, put new gas in. i need some ides please this thing is driving me crazy
make sure the e-brake isn't on, or the wiring isn't messed up. also the TORS can throw fits that will give similar symptoms also. B)
Edited by MILO
I would bet it's the TORs system. The brain is behind the left side of the radiator (when your sitting on it) unplug it and try again.
362471[/snapback]
Hey Mikey... If you want, come over and get that single carb and intake to bolt on there and see if it works. If it does, then you know you have a TORS problem. I wasnt even thinking TORS. I havent messed with stock carbs in a long time. Or, since its not raining yet today, bring your shee over. We'll get er done. Just a thought...
362477[/snapback]
I agree, that's what I'd try first...
Even if you put the single carb system on, you will still have to unplug the TORS system to do it. SO, why go through all the trouble of changing the carb system to find out if the TORS is the problem? Just unplug the module. Then order yourself up a TORS removal kit. It gives you new carb tops, and an idle kit. One of the best few dollars spent for stock carbs....
Make sure your coil isn't jumping to ground at the higher rpm's. Rev her up in the dark with all lights off, and you will see it if it jumps to ground, just look at the coil where the wires plug in.
Definately do the tors gig, coil would be my next place to look after that...may unscrew your plug caps, clip the wires a bit & rescrew them on...checked for air leaks? does it backfire at all?
363496[/snapback]
If the bike will sit there and idle,but the moment you hit the throttle it bogs.I almost guarantee you it's the TORS.Those big bulky things on top of your carbs(big pieces of junk).Back when I had stock carbs.,I had mine act up when I just washed it.If you've tried everything,try this.The wire that go to the perch where your clutch lever mounts to.At the perch,see the plug that plugs into the perch.Unplug it.About 2 or 3 inches from the plug,cut the wire into.There will be 2 separate wires inside.Put the plug off to the side.Now with the wires.Peal back the coating on both of the wires.Wrap them together.Start the bike.Problem solved?If it doesn't work just put the wires back together with the plug.This solution fixed one of my friends banshees.
Edited by RDZ350
check the rev limiter switch on the clutch perch.if it,s not pluggeg into the perch it cuts your rpm off.if you take it off you have to disconnect it from the wiring harness,or you'll only have about 1500 rpm.
i went thorugh all of your sugestions and It was the peice that plugs into the clutch perch! I pulled it out and messed with it and moved my e brake peice back and now it runs.I would on never looked at that thing i didnt even know about it. thanks a lot guys you saved me a lot of time and money
get a factory Yamaha Clutch, it's like $35 (it's adjustable and good as any). Ditch the Parking Brake complealty and get the blockoff I could not believe how long I rode with the stock clutch after getting the factory one.
i had the same problem but haven't had tors on in it years. i unplugged the computer and pulgged it back in and runs great.........but i have no lights what so ever..heads or tail.any1 have any suggestions.it all happened after washing it.p.s. put on a new stator already.the bike may have dried out to make it run good but lights are an issue for me. i ride at night all the time.
You can remove the parking brake and switch then cut the perch with a cutting wheel to make it look like any other perch. That way you don't have to buy one.
