kaos646
kaos646's Achievements
  1. check the rev limiter switch on the clutch perch.if it,s not pluggeg into the perch it cuts your rpm off.if you take it off you have to disconnect it from the wiring harness,or you'll only have about 1500 rpm.
  2. thanks alot jarmshee
  3. what kind of compression should i have with 20 degree domes,I used to have a chart but can't find it.if anyone knows or has the link to get the chart
