anybody that have Shearer pipes have a problem mounting them because the o rings in them make the fit soo tight that they won't slide over the exhaust (manifold) flange at the motor. the o rings i have are an FMF set. they came with 4 springs. are different o rings available? somebody help me out . by the way these babies scream
i know! i don' wanna have an exhaust leak. especially there. maybe dunedemon or someone else can let us know where to go or who to get some from.
361162[/snapback]
Put alittle oil on the oring and push it on Don't be a wimp :)
hey oilsmoke, i tried that, i was thinking about using somethin to pry them on with but i'm afraid of denting and scratchin them. i was pushin as hard as i can and they won't go up and over. they're so tight that even if i got them on i have no idea how i'd get them off again.
Edited by sandman121383
i would first ry them w/no o-ring.if they go on no problem take your o-rings to a tractor sales place(like a place that sells new holland or johndeer or kabota).they have tons of different o-rings and you can get a thinner 1.
I would call Matt at Shearer and or email them ask the what size oring dia to use.
I have K&S gasket set and My shear when right on. Maybe the FMF are little bigger dia.
i emailed Shearer a few times and never got a reply. other than goin to a local tractor dealor all i got left to try is an advanced auto that's 10 mins away. so m2orrow i'm gonna go see if they have ne that will work.
I lubed them up real good with grease and the right one went on pretty easy. The left one I greased, then heated with a heat gun and it went on with brute strength. Right one fits great, the left one we shimmed out to miss the head. Most HP inframe pipe we dynoed.
anyone know how to fix an exhaust leak? its not on my quad, its my uncles banshee. when we were loading up the quads i noticed alot of stuff around his exhaust on the motor, and i told him you know "you have an exhaust leak". he told me that it's not an exhaust leak, 2 strokes just do that :rotflmao: , i just laughed.
Toomey T5 O rings and a touch of antifreeze for lubricity is what I use, they go on with no problem this way. For those with exhaust leak issues at the cyl head, may I suggest using silicone O rings, NOT rubber.
I talked to the guys at Shearer and they said use the stock o-rings. They also said to use the stock springs, hangers and clamps. Personally I would like a different set of clamps.
