for some reason my shee is revving fast but doesn't make any power. i mean it feels normal but then it never gets into the powerband never really opens up at wot. ( it doesn't bog at all)
so i figure i must be lean but i pull both plugs and they look great( tan cardboard color). it was jetted back when it was about 60 degrees and now its about 70. i haven't changed anything since it was jetted
i also tried running it with the choke on and that didn't help at all
i also cleaned my filters and it made no difference.
it seems to lead to the idea that i'm too rich, but the rev with no power is usually a sign of lean jetting, right?
it also idles kinda higher than normal
someone also told me that weak reeds can lead to this problem.
any ideas?
Edited by joshv5.0
no mods at all . the bike sat for a couple of weeks then this happened so maybe its bad gas.
i don't think its a clutch thing because it doesn't feel like its slipping into nuetral
Edited by joshv5.0
i'd check my carbs fo sho!!! then tear into the clutch .. but having it rev higher then norm doesnt seem like a clutch failure... do you run pump or race.. pump wouldnt go bad.. and i've let my 114 sit for 2 weeks and was still good... but def check those carbs for any clogg... take em all out and get you a lil sewing needle and poke em!the jets that is ;)
Edited by NEVER SATISFIED
359854[/snapback]
Your clutch disks could be worn which would apply less "grabbing force"; i.e. it revs but doesn't pull hard. A clutch that is out of adjustment would give the exact symptom you are describing. :shrugani: I went through this with my banshee a couple months ago
359864[/snapback]
yep after further inspection i think i have a clutch problem
i will let you guys know more as it goes on
thanks for the help so far
