superbanshee03 Posted April 19, 2005 Report Posted April 19, 2005 I have a set of 33pwk carbs and I think the needle is wrong. The guy I bought them from said he had them on an rz. The mid range is kinda slow or boggish, I have moved the clip all the way up and it helped but I dont think it is still right? What needles do you guys run in your 33pwks or what do you recemend for me to try? Mods in signiture. Also I have # 5 slides if that makes a difference> Quote
sredish Posted April 19, 2005 Report Posted April 19, 2005 I have a set of 33pwk carbs and I think the needle is wrong. The guy I bought them from said he had them on an rz. The mid range is kinda slow or boggish, I have moved the clip all the way up and it helped but I dont think it is still right? What needles do you guys run in your 33pwks or what do you recemend for me to try? Mods in signiture. Also I have # 5 slides if that makes a difference> 357452[/snapback] Did you try moving the clips all the way down (moving the needle up), which would richen it and maybe eliminate the bog? Is it a smooth bog like in a lean condition or is it wet sputtery sounding? Quote
locogato11283 Posted April 20, 2005 Report Posted April 20, 2005 my bro has cgl needles in his 33mm pwk. they seem to work very well. im thinkin about gettin a set of them to try in my 35mm carbs Quote
superbanshee03 Posted April 25, 2005 Author Report Posted April 25, 2005 Its kinda smooth, I have run a plug check and seams alright, I think I am slower with these carbs, I ran faster with my stock carbs. Quote
white trash Posted April 26, 2005 Report Posted April 26, 2005 I run the CGL in mine. Works tits so far Quote
JArmShee Posted April 26, 2005 Report Posted April 26, 2005 DEJ on my 33wpk it could be better but it does run strong. Quote
