Droppedatbirth Posted April 2, 2005 Report Posted April 2, 2005 (edited) Hey, well my banshee was wrecked down a hill, anyways the throttle is broke i orderd a new one, The Front rim Bent And Grinds On The Spindle,,, so i hammerd the rim in so it doesint hit the spindle and now as i look at the way it turns it turns way more to the left ( shifter Side ) and hits on the controll arm! so what would you guys think is also bent i cant visualy see what it is anyone had this happen also? Thanks alot ((( Yes i edited it i was pissed and typed too fast at the time ))) ((( ALSO ))) anyone have a stock front banshee rim they would sell me, Tire or no tire dont matter, whatever is cheaper Here Are some pics < -- hits controll arm Edited April 3, 2005 by Droppedatbirth Quote
tithead Posted April 2, 2005 Report Posted April 2, 2005 in english please??? tell your mate to get a new girlfriend too! Quote
Droppedatbirth Posted April 3, 2005 Author Report Posted April 3, 2005 Hey, well my banshee was wrecked down a hill, anyways the throttle is broke i orderd a new one, The Front rim Bent And Grinds On The Spindle,,, so i hammerd the rim in so it doesint hit the spindle and now as i look at the way it turns it turns way more to the left ( shifter Side ) and hits on the controll arm! so what would you guys think is also bent i cant visualy see what it is anyone had this happen also? Thanks alot ((( Yes i edited it i was pissed and typed too fast at the time ))) 348817[/snapback] Fixed IT ! LOL Quote
tithead Posted April 3, 2005 Report Posted April 3, 2005 Fixed IT ! LOL 348824[/snapback] well done... im proud! Quote
Droppedatbirth Posted April 3, 2005 Author Report Posted April 3, 2005 well done... im proud! 348834[/snapback] Thats for the feedback on the problem you sure did suggest alot there bud Quote
white trash Posted April 3, 2005 Report Posted April 3, 2005 could have tweaked a tie rod, or a tie rod end. that would make it turn more Quote
itsaripper Posted April 3, 2005 Report Posted April 3, 2005 At the end of the stearing stem is a little tab that limits the stearing. When it gets a hard hit it can bend over or bend away from where its supposed to be. Mine had been pushed over and cracked the ends, when I got my banshee. I took a three foot bar and hammer and bent it back. Then welded the cracks. Don't hold the weld to long on the tab, there is a bearing in there. Quote
Droppedatbirth Posted April 3, 2005 Author Report Posted April 3, 2005 At the end of the stearing stem is a little tab that limits the stearing. When it gets a hard hit it can bend over or bend away from where its supposed to be. Mine had been pushed over and cracked the ends, when I got my banshee. I took a three foot bar and hammer and bent it back. Then welded the cracks. Don't hold the weld to long on the tab, there is a bearing in there. 348958[/snapback] can you take apic of that please i dont see what your talking about thanks for the input Quote
sheeweet Posted April 3, 2005 Report Posted April 3, 2005 (edited) WHAT THE!!!!! Were you dropped at birth or something? Why let some broad drive your new Shee?? Dude, she owes you a blow job, she didn't break her jaw, did she? J/K I hope she didn't get hurt, you didn't mention it. Sorry that happened, you'll get it fixed. Edited April 3, 2005 by sheeweet Quote
Droppedatbirth Posted April 3, 2005 Author Report Posted April 3, 2005 WHAT THE!!!!! Were you dropped at birth or something? Why let some broad drive your new Shee?? Dude, she owes you a blow job, she didn't break her jaw, did she? J/KI hope she didn't get hurt, you didn't mention it. Sorry that happened, you'll get it fixed. 349105[/snapback] LOL, ya she didint get hurt i should get a hand job atleaste Quote
broke Posted April 4, 2005 Report Posted April 4, 2005 Dude, she owes you a blow job That's creepy, when I read the name of the thread that's exactly what popped into my head. Even if she did hurt her jaw, her ass should be fine if she hit head fisrt. Quote
Cotton eyed Joe Posted April 4, 2005 Report Posted April 4, 2005 That's creepy, when I read the name of the thread that's exactly what popped into my head. Even if she did hurt her jaw, her ass should be fine if she hit head fisrt. 349280[/snapback] Damn right. Id say she owes you 2 or 3 hand jobs and what ever else you can come up with for a LONG TIME. Quote
2stroker Posted April 4, 2005 Report Posted April 4, 2005 At the end of the stearing stem is a little tab that limits the stearing. When it gets a hard hit it can bend over or bend away from where its supposed to be. Mine had been pushed over and cracked the ends, when I got my banshee. I took a three foot bar and hammer and bent it back. Then welded the cracks. Don't hold the weld to long on the tab, there is a bearing in there. 348958[/snapback] Same thing happened to mine. The metal stop on the frame bent forward. As a result, the "ears" on the steering stem no longer made contact with the stop. The only thing that limited movement was the inside of the rim making contact with the lower a-arm. I hammered the stop back straight but didn't weld it yet. It's holding up so far. But it should be welded. I've heard of incidents where the handle bars locked at full left or full right because of this. You definitely need to get it fixed. Quote
Droppedatbirth Posted April 4, 2005 Author Report Posted April 4, 2005 Same thing happened to mine. The metal stop on the frame bent forward. As a result, the "ears" on the steering stem no longer made contact with the stop. The only thing that limited movement was the inside of the rim making contact with the lower a-arm. I hammered the stop back straight but didn't weld it yet. It's holding up so far. But it should be welded. I've heard of incidents where the handle bars locked at full left or full right because of this. You definitely need to get it fixed. 349428[/snapback] I looked at those they look fine, they are in the same position, so i dont know what to look at next any suggestions? Quote
