now i am confused :confused::confused:
locogato11283 why should i not use ceramic?
RNBRAD why should i use it?
When i first bought them i used the high heat paint, and for sure it peeled!!
:confused::confused::confused::confused:
Edited by jaysvt
loco isnt saying to never use it, he is syaing he has never used it, so he wont comment because he has no personal experience with it...correct me if im wrong
but back to your question, chrome would be my first choice, followed by ceramic coating, from what ive heard is very good
346108[/snapback]
you are correct. i havent ever used ceramic coating. i have heard it holds up well tho. i just figure most ppl have a powdercoater nearby that an do the heat temp PC.
If you're considering high temp paint, look into using high temp ceramic paint. I've never used it myself but it can handle higher temperatures than regular high temp paint. Most high temp paint in the can can go up to 1000*. Some ceramic paints can go up to 1500* (Duplicolor) - 2000* (VHT). Like I said, I've never tried it myself. But if the stuff printed on the can is accurate, it might be worth a shot. If it dont work, you're only out about $8 for a can.
Edited by 2stroker
  • 1 year later...
