hey i have apiar of brand new racing boots ive had for 2 years and when i put on 2 year ago i went out on the track to start the race and i couldnt shift my 4 wheeler becasue i couldnt move my ankle, how the hek can i breK THESE THINGS IN!! ha they are useless if i cnt shift??
From my experience, the best way to break 'em in is to simply wear them, around the house, in the garage....eventually they'll be broken in. This isn't the easiest way to do it, but they just form to your legs/feet a little better. Try doing a search, I remember having the same problem and read that you can coat 'em in oil and put them in a black garbage bag to let it sit outside in the sun (I've tried this a couple times w/ my thor boots and I didn't notice a difference).
OR you could go buy some Tech 8's! :drool: And not worry about breaking them in.
Riding boots were made to be stiff. I have had my Tech 8's for a lil over 2 years, and they (to me) still feel as stiff as the day i got em. You'll never get em (atleast in my experience) as brokin in as an old pair of old sneekers, but who wants flimsy riding boots...The more you wear em, the more used to em you 'll get, and the shifting thing will become 2nd nature to you.....that or you could move your shifter up a little.
:shrugani:
345512[/snapback]
Isn't the point of them to keep your ankle somewhat stiff so u don't break it in the event of a crash. Mine never did break in completely, but wearing them around the garage helps, I just raised the shifter a notch and learned so shift with my whole leg. :shrugani:
Like everyone says "Wear them". Walk the track before a practice or race with them. They protect the ankle so they will be stiff there. You will get what you pay for but I like to balance cost with use. The Thor boots I have are taller than most at the toes so I had to raise my shifter one notch to shift. You will have to learn to shift with your leg and might have to sit more to the front. I still fight them in drag races, I some how can't hit fifth every time like a pair of sneakers.
yea, lol the tech 8's are the shiz,
345542[/snapback]
you should check into the tech 10's. thats a fuckin boot right there.
Guest nightmare
Somebody told me you can use the oil they use to break in a baseball glove. They said it works very well.
for all the protection they might provide for your shins and ankles, what about your toes. i'd rather wear my steel toe work boots if riding boots having nothing in the toes.
I dont know if it will work the same but for hockey skates the way we always breakem in is to soak em in as hot of water as you can stand and walk around in em for about half an hour, i did it with my fxr snowmobile boots and it worked the same
I stood with my toes on a step (with my ankles off the step) and pushed my ankles down for awhile, and that seemed to help my boots when I got them, other then that I raised my shifter up and notch or two so I could get my boot under it easier :cheers:
I myself would be more likely to crash and break my neck from missing a shift rather than break my ankle from a crash. But I only ride recreationally, no MX racing. If you can't get the feel for stiff boots then there are boots that have some up down ankle movement but not side to side like Sidi's but they are a bit more expensive. I have 2 pair or sidi street boots, one for the street and one for dirt riding. They are soo comfortable you can wear them to the office all day like shoes, but they are pricy, and not quite as much protection as full on MX boots.
